Old 04-15-2005, 10:17 AM   #1
nighthunter0405
Member#: 82535
1996 Impreza 2.2L
Default Need help 96 2.2l wont rev over 4k will driving
my 96 impreza has a problem reving past 4k rpms in pretty much all gears but mainly 3rd and 4th. it cuts of like when you redline. i know it has a couple of engine codes that are being thrown one has to do with i think the maf sensor and the other is the vehical speed sensor . i was wondering if either of those were the problem. this is really annoying when you try to pass someone and suddenly the car wont accellerate cause it seems to be redlining but at 4k please help me
nighthunter0405 is offline   Reply With Quote
Old 04-15-2005, 10:40 AM   #2
DreddRS25
Member#: 51642
2008 WRX
For the most part, people who have this problem either have a dirty/broken MAF or it could possibly be the throttle position sensor. Though I would lean toward the MAF.
If you pull the MAF sensor out of the intake (Carefully!) and the car is able to rev past 4k then it is either broken or dirty.
Searching a bit in this forum may reveal some better answers. GL!
DreddRS25 is offline   Reply With Quote
Old 04-15-2005, 11:25 AM   #3
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
HEHEHE...I just fixed this problem on my 95 scooby...
MAF sensor for sure. Try cleaning it...then try replacing it...if this doesn't work, check the wires. Two of mine were snapped in the middle
speed sensor is in the tranny and shouldn't be too much of a problem, but may impact your speedo
cheers,
//marcus
marcus12 is offline   Reply With Quote
Old 04-15-2005, 03:57 PM   #4
anders8
Member#: 26658
1 Love Grassroots
NASA Rally Sport FTW!
Alternatively, it could be your ENTIRE problem.
Your ECU won't let the engine rev over 4k under load when it's parked. But with no speed sensor, the car _thinks_ you're parked, naturally enough.
Searches will reveal more on this.
Anders
anders8 is offline   Reply With Quote
Old 04-15-2005, 04:27 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes it's the speed sensor. If the ECU doesn't get this signal you will have a 4k rev limit.
Old 04-15-2005, 05:00 PM   #6
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Check the MAF..
I pulled mine yesterday just to see what happens and you hit the rev limter at 4K.
SubaruImpreza_power is offline   Reply With Quote
Old 04-16-2005, 08:25 PM   #7
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
sorry I didn't specify...it could be EITHER. What CEL codes are you getting? You should be OBDII, so hit up AutoZone for a free CEL check. They'll tell you the codes.
I only say it's definitely the MAF sensor because that's exactly the problem I had when mine went. My speed sensor was loose and all that happened was my speedo didn't work at all. Car wasn't revving over 4K anyway due to the MAF sensor, so I can't tell ya if the speed sensor put the car in "limp home" mode.
But seriously...check the MAF sensor because that's what it sounds like. If your speed sensor was busted, your speedometer shouldn't be working either.
//marcus
Old 04-17-2005, 04:05 PM   #8
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
lack of signal from the speed sensor send the ECU into limp mode. this is one of the rare non-dangerous problem that can do that, and it is to prevent mileage-screwing. otherwize, all major engine problems detected by the ECU will also cause the limp mode to occur. All the codes you get could been related like engine speed and vehicle speed not matching, or engine load vs speed not matching...
NicEJ25 is offline   Reply With Quote
Old 04-20-2005, 08:58 AM   #9
nighthunter0405
Member#: 82535
1996 Impreza 2.2L
alright i will go to autozone today ive been looking for someone to run the codes for me
NEED help with ecu trouble codes please... wont rev over 1500rpm Bcoolsti Service & Maintenance 14 08-16-2009 08:55 PM
Car wont rev over 5000 RPM, pulled Map sensor and cars fine.... Please help!!! Cautionjump Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-08-2007 11:45 PM
need help on 2.2L impreza performance Dsub15 General Community 0 04-16-2006 04:52 PM
OK need help here 2.2l into 93 L ImprezaRacer Subaru Conversions 4 05-01-2004 11:17 AM
Will high flow cat work with 96 2.2L? 96Lconversion Normally Aspirated Powertrain 6 02-20-2001 08:35 PM
