Old 04-15-2005, 11:36 AM   #1
popnfresh
Member#: 72832
Default How much free play should be in 05 sti clutch
when i start to press the clutch in, it is a bit looser for the first 1/4-1/2 inch of travel before meeting more resistance
its not completely loose, but i can feel a definate point in which i meet more resistance after pressing the pedal down a bit, is this normal?
popnfresh is offline   Reply With Quote
Old 04-15-2005, 03:50 PM   #2
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
You have a hydrolic clutch that is self adjusting, unless there is air in the system. The pedal has an adjustment for feel located under the dash above the pedal.
But yes what you describe is normal for almost any car.
wrx plus is offline   Reply With Quote
Too Much free play in steering response njk8010 Brakes, Steering & Suspension 3 08-24-2007 10:36 PM
STD tests, how much pain will I be in. BhamRoadrunner Off-Topic 74 08-09-2006 11:50 AM
04/05 STi guys, How much boost do you see in 1st and second gear? The_Urban_Knight Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 08-21-2005 01:36 PM
The only Recaro that should be in the STi TreyS Interior & Exterior Modification 33 03-07-2005 10:20 AM
how much height play is there in the tein wagon coilovers dubX1 Brakes, Steering & Suspension 3 10-03-2002 02:29 PM
