Old 04-15-2005, 06:24 PM   #1
blackie
Member#: 42979
03 wrx
blizzzack stage IV
Default Oh damn! i think i found out where all my oil is going.
Ive been posting things about my oil disapearing in the past month or so and just today i noticed that my car has been smoking alot out of the tail pipe when ever i get on it hard or in mornings when i first take off so i asummed the worst today thinking one of my rings or ringlands was broken, i did a compression test with my car still warm and got these results average out of three test per cylinder
#3=161psi #4=162psi
#1=158psi #2=163psi
The plugs looked normal some white speckles and stuff but no oil
That being said im almost sure its my turbo seals on my vf-34 which only has like 20,000 miles on it Before i take my turbo off to have it rebuilt, is their any other reason that silver looking smoke comes out of my car and reeks of oil smell??? I would hate to take my turbo off any find out it was somthing else, Thanks in advance.
blackie is offline   Reply With Quote
Old 04-15-2005, 06:27 PM   #2
InfamousDX
Member#: 25413
#3=161psi #4=162psi
#1=158psi #2=163psi
Are IHI turbos even rebuildable?
Old 04-15-2005, 06:28 PM   #3
tekfoc
Member#: 21392
2016 C63S AMG MB
Iridium /MB C300 4MATIC
sounds like the turbo seals to me. good luck.
tekfoc is offline   Reply With Quote
Old 04-15-2005, 06:29 PM   #4
blackie
Member#: 42979
03 wrx
blizzzack stage IV
I hope they are rebuildable, why wouldnt they be?
Old 04-15-2005, 06:54 PM   #5
blackie
Member#: 42979
03 wrx
blizzzack stage IV
How can i tell if it is my turbo seals for sure?
Old 04-15-2005, 07:42 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
#3=161psi #4=162psi
#1=158psi #2=163psi
...white or silver...like tiny little silver balls??? Look with a magnifying glass....what do you see????
Old 04-15-2005, 08:41 PM   #7
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
bits of piston? Signs of detonation....
jigga is offline   Reply With Quote
Old 04-15-2005, 09:43 PM   #8
blackie
Member#: 42979
03 wrx
blizzzack stage IV
i will post pics of my plugs later tonight. I just put some valvoline vr1 20w50 in to see if the smoke goes away tonight. the motor is definatly alot quieter with the dino oil.
Old 04-15-2005, 09:45 PM   #9
blackie
Member#: 42979
03 wrx
blizzzack stage IV
well uncle scotty it does look like some silver balls , i will show you guys later when i get back from skateboarding
Old 04-15-2005, 09:48 PM   #10
blackie
Member#: 42979
03 wrx
blizzzack stage IV
i havnt heard any detonation and i do have a good ear for that stuff, having owned many many modified turbo and supercharged cars. the car runs fantastic
Old 04-15-2005, 10:26 PM   #11
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
they do say that there is almost always some minor knock present, and that whether or not damage occurs depends on whether there is a severe series or single event.
Old 04-15-2005, 11:05 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
...tiny, little, silver balls on the plug insulators are bits of melted piston crown....you have been detting and you need to stop whatever it is you are doing to get those little balls on the plugs...bad juju....just 'cuz you can't hear it means nothing...
Old 04-16-2005, 12:09 AM   #13
hotrod
Member#: 14141
2002 Impreza WRX
Like Uncle Scotty says, bad sign if you have "salt and pepper" signs on the plugs.
Those little aluminum balls are persistant, so they may indicate a detonation event that occured several days ago. You can clean the plugs with a clean tooth brush and put them back in and make a test, then check to see if they come back.
You won't be able to hear high rpm detonation, too much engine noise going on. Big V-8's give a much more audible detonation than the stuff that will kill our engines.
Given where you live it might be a heat issue. You might be able to resolve it by putting in a cooler thermostat, and a low antifreeze coolant mix ( about 20-25% antifreeze to water with water wetter). If that does not fix it you need to look at one step colder plugs if your still on the stock heat range, and backing off the boost a bit.
Your most prone to detonation in the midrange rpms near torque peak, so high boost in hot weather and long pulls in higher gears near 4000-6000 rpm are a good way to break an engine if you don't have good fuel octane to protect you.
Take care not to flog the car hard when its really hot under the hood like after its been parked for 30 min or you have been stuck in traffic for a while, give it a couple miles to cool down on the road before you get on it hard.
In the summer time I either turn down the boost a couple psi or spend the money to bump the fuel octane up to the 95+ octane range.
Larry
hotrod is offline   Reply With Quote
Old 04-16-2005, 12:31 AM   #14
fatray
Member#: 18150
2002 WRX Wagon EJ207
Velocity Red, Liberal kit
IHI turbos are not rebuildable is what I was told a year ago by more then one vendor on this board.
fatray is offline   Reply With Quote
Old 04-16-2005, 12:48 AM   #15
blackie
Member#: 42979
03 wrx
blizzzack stage IV
salt and pepper look does not mean your detonating. When my car was completely stock the original plugs had those little white spots, its pretty common. Its the actual little silver colored balls that means your detonating.
Can I email my plug picture to someone because i couldnt get imageshack.com to work because the picture is 2.12MB. thanks
Old 04-16-2005, 01:40 AM   #16
hotrod
Member#: 14141
2002 Impreza WRX
salt and pepper is what the drag racers call it when you see the silver balls or black spots from carbon blown off the piston crown on the plugs.
Larry
Old 04-16-2005, 02:15 AM   #17
SchnorrCS
Member#: 66383
Tom@ Kartboy is my
Daddy!
Could be turbo seals. Take off the DP and check the mouth. If it's oily, problem found. While it's off, you could check your shaft play too.
SchnorrCS is offline   Reply With Quote
Old 04-16-2005, 12:09 PM   #18
blackie
Member#: 42979
03 wrx
blizzzack stage IV
Larry
ok then i guess these two companys must have it all wrong then, just look at what they say normal is- notice the salt and pepper look
Old 04-16-2005, 12:10 PM   #19
blackie
Member#: 42979
03 wrx
blizzzack stage IV
Old 04-16-2005, 04:56 PM   #20
Uncle Scotty
Member#: 16200
OK buy Nates beans
blackie....we are not talking about the same thing, here.....re-size your pics and/or post them to
photobucket.com
or
tinypic.com
and link from there....
think my theromostat is going out wizzle-stick Texas Impreza Club Forum -- TXIC 7 06-21-2009 02:23 PM
just found out where the army is going to station me and no it's not starting in iraq tiggerduc General Community 41 09-28-2008 11:50 PM
Where did my oil go? HELP! runnah New England Impreza Club Forum -- NESIC 15 05-17-2005 10:00 AM
Where did all my oil go?! SF_WRX_94107 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 11-24-2003 10:42 PM
Oh where oh where did my oil go? Rubasu Normally Aspirated Powertrain 15 04-25-2002 08:23 PM
