Old 04-15-2005, 07:05 PM   #1
ILwrx
Member#: 56597
Default fuel pump relay question
Hello everyone.
I installed dual walbros intank fuel pumps, Y-ed them together into larger hose and so on. I wired the pump on ths same connector. just spliced the wires and hooked both of them. Now I ran into problems. When I try to start the car it is starting, the pressure goes up and them slow goes down until car stalls. Basiclly my fuel pumps goes offline when I start the car. Is it because it is too much wireing both pumps on same wires? How can I wire them to solve this problem? Wire them directly from the battery though the ralay of the starter? Is it fine and safe? Maybe some other way so I wan't have to run 2 wires from the hood to the trunk? Thank you.
ILwrx is offline   Reply With Quote
Old 04-15-2005, 08:38 PM   #2
Damien3082
Member#: 68710
2005 Impreza WRX
Pearl Blue
Why dual Walbro's? Isn't one sufficient?
Damien3082 is offline   Reply With Quote
need fuel pump and fuel pump relay 4/18/10 raceckr MWSOC Private Classifieds 1 04-18-2010 03:05 AM
Fuel Pump Relay Control and Airconditioner Cut Relay Control modifiedauto Newbies & FAQs 0 09-19-2007 08:43 PM
Fuel Filter replacement - where is fuel pump relay? SeenDubAYouAreEx Newbies & FAQs 4 07-11-2007 09:29 PM
fuel pump relay question imprezaclipse Subaru Conversions 3 06-13-2007 04:57 PM
Fuel Pump Relay Question NickSTi Normally Aspirated with bolt-on Forced Induction Powertrain 2 06-03-2002 03:31 PM
