Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Old 04-15-2005, 10:46 PM   #1
IA Performance
Vendor Sales Rating: (60)
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Default Sti 5 speed and 6 speed gear boxes in stock!!
Check out our other vendor postings here:
Suspension/Brakes/Handling
http://forums.nasioc.com/forums/showthread.php?t=735011
Interior (Sti Wagon interior and Right Hand Drive Conversion)
http://forums.nasioc.com/forums/sho...04#post10124004
Engine/Power/Exhaust (Sti motors, etc)
http://forums.nasioc.com/forums/showthread.php?t=539826
Exterior/Dressup (JDM Takeoffs)
http://forums.nasioc.com/forums/show...8#post10124678
Type RA
Act fast since these Transmission deals will not last!!!! All items in stock unless denoted otherwise.You must mention this ad for these prices.
*****NEW*****DCCD complete control units.- $839+ship
That's right, brand spanking new direct from Japan to your door. These allow nonDCCD equipped vehicles to control DCCD transmissions. Great for Dynos, tracks, off road, and all around town use.
  • all cords
  • roller switch for interior manual control
  • DCCD computer
  • can be made to wire in w/ DCCD equipped gauge clusters
  • special order item
JDM ver8 Sti RA Spec C Transmission- $SOLD
JDM ver7 Sti nonDCCD Suretrac Transmission- $ SOLD + ship (next 3 units arrive June 30th)
  • nonDCCD
  • SURETRAC (LSD front diff)
  • Includes shift linkage
  • Free lightly used 6 speed clutch assembly w/ flywheel.
  • *******FREEBIE****** Sti Sedan front axle set
JDM ver7 Sti nonDCCD Suretrac Transmission W/ R180 REAR END ASSEMBLy (minus calipers). - $SOLD + ship
  • 21,000 KM of use
  • NonDCCD
  • Driveshaft
  • JDM r180 differential
  • Trailing Arms
  • Lateral Links
  • E-brake assembly including shoes
  • Rear Xmember and all mounting hardware
  • Rear 'T' shaped diff mount (not pictured)
  • Brembo 2 pot rear calipers add $800, slightly scuffed condition
  • Rear sway bar not included
Subaru 2 Pot Complete rear end from our RA. Crazy price mark down. For use w/ JDM 6 speed SOLD
R180 bullet proof diff, 3.90 gearing
  • Sti beefy rear axles
  • Sti Hub/knuckle
  • Sti Subaru 2 pot (black) brake assembly
Sti RA Complete Gearsets- $1499 shipped
  • Main Shaft
  • 1st Driven Gear
  • 2nd Driven Gear
  • 3rd Drive Gear
  • 4th Drive Gear
  • 3rd/4th Driven Gear Cluster
  • 5th Gear Set
  • 3rd/4th Shift Rod
  • Case Gasket
  • Speedo Gear METAL (will not wear out like whilte plastic ones do)
  • Lock nuts
  • 4th Thrust Washer
  • Front Oil Seal
Ratios are as follow:
  • 1st Gear : 3.083
  • 2nd Gear : 2.062
  • 3rd Gear : 1.545
  • 4th Gear : 1.151
  • 5th Gear : 0.825
Sti ver6 Complete Built Sti Gearboxes.
Faster track times, stronger gears, next to zero down time. Just drop out your old wrx 5 speed in favor of our assembled unit. We have at minimum 1 complete case in stock on a daily basis. Same rations apply as those listed above. $800 refundable core charge applies. Call for pricing.
  • Main Shaft
  • 1st Driven Gear
  • 2nd Driven Gear
  • 3rd Drive Gear
  • 4th Drive Gear
  • 5th Gear Set
  • 3rd/4th Shift Rod
  • Case Gasket
  • Lock nuts
  • 4th Thrust Washer
  • Front Oil Seal
  • All Case Seals
  • New Bearings
  • New Syncro Set
  • Subaru Master Tech Assembled- only the best for our customers
  • 2 day lead time for build required
All major Credit Cards, Mail Orders, Cash, and Paypal accepted. Salesmen by the phone awaiting orders.
Stephen
www.IAPERFORMANCE.com
Subaru Audio Upgrades, Click the Subaru
1687 W Grant Rd #102
Tucson, AZ85745
520-882-2821
520-232-3709 fax
M-F 10am-7pm
Click on the Ebay Button for current auctions
IA Performance is offline   Reply With Quote
Old 04-18-2005, 04:06 PM   #2
HeMan1320
Member Sales Rating: (2)
Member#: 26067
2003 WRX
Open Sourced
I have Front and Rear LSDs I do not want to replace. Can I still use the STi RA gear set?
HeMan1320 is offline   Reply With Quote
Old 04-18-2005, 04:44 PM   #3
IA Performance
Member#: 25194
Dark Gray
SHould be good to go. WHen you do the gears you are only really replacing the center area of the tranny (internal wise). The center diff, and front diff are up to you. The gears change the gear ratios, but do not change the center diff ratio.
Click on Icon
Stephen
Tucson, AZ 85745
520-882-2821
520-232-3709 fax
M-F 10am-7pm
Old 04-18-2005, 05:58 PM   #4
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
do you carry the non-RA gearset? I've always gone between the 2 because of gas mileage.
Old 04-18-2005, 07:25 PM   #5
IA Performance
Member#: 25194
Dark Gray
Just RA sets at this time. Optimal acceleration, gas mileage will take a small hit, but sometimes sacrifices are worth it
Stephen
Tucson, AZ 85745
520-882-2821
520-232-3709 fax
M-F 10am-7pm
Old 04-20-2005, 07:15 PM   #6
ravi
Member Sales Rating: (23)
Member#: 37597
2004 STi w/fp green
Could you please pm me pricing info, re:
Sti ver6 Complete Built Sti Gearboxes shipped to SC.
ravi is offline   Reply With Quote
Old 04-20-2005, 07:32 PM   #7
IA Performance
Member#: 25194
Dark Gray
PM sent.
Stephen
www.iaperformance.com
Old 04-20-2005, 10:03 PM   #8
ravi
Member#: 37597
2004 STi w/fp green
thanks got it.
forgive another noobie questions...
this is sent dry, or is thier fluid inside the tranny?, and if no, what do you reccomend, and how much will it need.
also, 5th gear is stock? if not, how would interstate cruising at like 80 be?
Old 04-20-2005, 11:25 PM   #9
IA Performance
Member#: 25194
Dark Gray
ravi- tranny is sent dry. We run Durablend 75/90 in our trannies with good results. I beleive that case holds right around 4 quarts. I can double check this though tomorrow. Mobil 1 synthetic works well in there too. I think it is 80/90. Both of these can be purchased at your local automotive store (pep boys, etc).
5th gear is also Sti RA. Crusing at 80 should be right around 4200-4500 rpm.
Stephen
Tucson, AZ 85745
520-882-2821
520-232-3709 fax
M-F 10am-7pm
Old 04-22-2005, 06:03 AM   #10
spoolinsuby
Member Sales Rating: (1)
Member#: 80182
Look ing for a GG
Wagon
You have a pm
spoolinsuby is offline   Reply With Quote
Old 04-22-2005, 03:31 PM   #11
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
Can I just keep my 5th Gear for MPG?
Old 04-23-2005, 04:55 PM   #12
line
Member Sales Rating: (3)
Member#: 76189
WRX: Parking Lot
Racer in Training
Hey guys, I was wondering how much it would cost for all the parts of a JDM 5speed (non dccd) swap would cost? Also about how much WHP and torque would the new setup be able to take? Thanks guys and hope to hear from you soon
P.S. I have a 5 speed WRX now
line is offline   Reply With Quote
Old 04-23-2005, 06:08 PM   #13
IA Performance
Member#: 25194
Dark Gray
Heman1320- you have a PM
line- you have a PM.
Stephen
Tucson, AZ 85745
520-882-2821
520-232-3709 fax
M-F 10am-7pm
Old 04-24-2005, 01:00 AM   #14
Davenow
Member Sales Rating: (21)
Member#: 23676
Is that a WRX box with the RA gearset built in it?
If so, and you can get one to Exeter Subaru in NH within like 8-9 days you 99% chance have a sale
I will also be needing a clutch and a serviceable stock weight flywheel, so let me know what ya got
Old 04-24-2005, 01:24 AM   #15
Soon2Bgreat
Member Sales Rating: (8)
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Got a 6MT slave cylinder you could part with? If not would a wrx 5mt work on a 6mt?
Soon2Bgreat is offline   Reply With Quote
Old 04-24-2005, 02:48 AM   #16
jake15
Member#: 36662
1990 legacy dohc 2.2
6speed w/ brembos bishes!
oops.
jake15 is offline   Reply With Quote
Old 04-25-2005, 01:56 AM   #17
InfamousDX
Member Sales Rating: (184)
Member#: 25413
Is it acceptable to dyno a car with the 35/65 split aka non-dccd trannies or dccd trannies that don't have it hooked up?
Old 04-25-2005, 04:06 PM   #18
Davenow
Member#: 23676
Just talked to you. No need to answer my post now SPoke to wife, she was ultra busy. As soon as I figure out what card I am putting this on I will call you back and you can get on building me a tranny
Old 04-25-2005, 07:27 PM   #19
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
will the DCCD setup on the top work in a 02 USDM WRX 5 speed tranny. If so, it should work in an 99-01 RS.
Patrick L is offline   Reply With Quote
Old 04-25-2005, 08:03 PM   #20
beecha91
Member Sales Rating: (16)
Member#: 55009
Look forward to the trans...Thanx again!
Don-
beecha91 is offline   Reply With Quote
Old 04-25-2005, 09:11 PM   #21
IA Performance
Member#: 25194
Dark Gray
Davenow- Sounds good, keep me in the loop. No used flywheels or decent lightly used clutches at this time. New Exedy and ACT ready to ship.
Soon2Bgreat- sure do. $40 + ship and it is yours.
InfamousDX- If you put a DCCD transmission on a Dynometer the center differential (DCCD unit) will begin to freek out. You run the risk of overheating it and blowing it out. If you have teh DCCD hooked up (via one of the DCCD kits we sell) then it will work fine on the dyno.
Top_Dog- yes, the DCCD computer system (sold seperately) is a standalone unit which will work in just about any application.
Beecha91- Crating it now. You actually picked up the last nonDCCD in inventory 2 more inbound in 1-2 weeks time though. No real shortage.
Stephen
Tucson, AZ 85745
520-882-2821
520-232-3709 fax
M-F 10am-7pm
Old 04-26-2005, 12:16 AM   #22
InfamousDX
Member#: 25413
Thanks Stephen... also.. how hard/involved is the wiring of the DCCD controller on a DCCD equipped trans (ie 04 us STI)???
Old 04-26-2005, 10:08 AM   #23
Davenow
Member#: 23676
forgot to call you back last night. Plan on hearing from me later today/this evening (eastern)
Old 04-26-2005, 02:44 PM   #24
IA Performance
Member#: 25194
Dark Gray
InfamousDX- not bad at all. We may do a write up on the install once we finish ours next week. Very few wires to hook in. Essentially power, ground, cluster (optional).
Davenow- Sounds good.
Stephen
Tucson, AZ 85745
520-882-2821
520-232-3709 fax
M-F 10am-7pm
Old 04-26-2005, 07:52 PM   #25
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
that price for the DCCD, does that include the center diff or what diff is needed.
FS-ILLINOIS: 05 6 Speed and 6 Speed PARTS! Mooneyes13 Drivetrain 24 01-16-2009 10:26 PM
FS: 05 6 Speed and 6 Speed PARTS! Mooneyes13 MWSOC Private Classifieds 12 12-26-2008 09:44 PM
wtb: 5 speed ra, 6 speed mt, or set of ra gears legacy2003 Private 'Wanted' Classifieds 6 04-12-2006 01:28 PM
who has a loud noisy gear box in their 6 speed? swift2fly Transmission (AT/MT) & Driveline 0 03-01-2006 03:07 AM
Version 6 STi RA and RA SE gears back in stock!!! Transmissions too!!! Gruppe-S Drivetrain 17 08-18-2005 09:43 PM
