Old 04-15-2005, 11:05 PM   #1
sti350zguy
Member#: 62823
2004 sti/350z Twin T
silver/Silver
Impreza WRX STi car will not go over 6ooo rpms
I have a 2004 sti with the following mods.
perrin front mount
aps sr55
pe 850cc
utec
tial 38mm external
perrin big maf
1 step colder plug
avcr boost controller
perrin turbo back
The car falls on its face at 6,000 rpms. It almost sound like you hit rev limiter. It will happen under heavy load over 14psi. We have changed the plugs checked the coils and grounds. Any one have an idea????? Please Help!!!!!!
sti350zguy is offline   Reply With Quote
Old 04-16-2005, 12:51 AM   #2
AZ04STI
Member#: 74098
2004 WRX STI
I ran into a simular issue on my STI. It turned out the middle switch on my UTEC was flipped the wrong way. The middle switch allows for fuel cut. Make sure you have it turned off. Hope this helps...
AZ04STI is offline   Reply With Quote
Old 04-16-2005, 10:53 AM   #3
sti350zguy
Member#: 62823
silver/Silver
checked the utec was not it, but thanks.
Old 04-16-2005, 05:59 PM   #4
ranmaru
Member#: 52050
chk your intercooler hoses
ranmaru is offline   Reply With Quote
Old 04-16-2005, 07:15 PM   #5
sti350zguy
Member#: 62823
silver/Silver
intercooler hoses are all ok. I took it off the dyno today and drove it. It is ok in 1-3 gear, it is in 4,5 and 6th. I think it is ignition but what could it be?
Old 04-16-2005, 08:04 PM   #6
Member#: 19577
2005 Sti
I've seen some inlets close up at high boost. Next time your on the dyno check and see if your turbo inlet is collapsing. It will feel like the car just drops power like you mentioned. I've never seen a stock one collapse but I've seen Perrin and even Samco at 22psi.
Tuan@grd is offline   Reply With Quote
Old 04-16-2005, 09:50 PM   #7
AZ04STI
Member#: 74098
2004 WRX STI
I have seen this a few times, but only with aftermarket turbo inlet hoses. I have darn near the exact setup, but stuck with the stock inlet because Rich at DYNOCOMP warned me of that exact problem with after market Turbo Inlets.
Old 04-17-2005, 01:56 AM   #8
sti350zguy
Member#: 62823
silver/Silver
I have a samco and watched it while dynoing and it does not move?
Old 04-17-2005, 03:31 AM   #9
AZ04STI
Member#: 74098
2004 WRX STI
What does your UTEC logs look like when this happens?
Old 04-17-2005, 11:23 AM   #10
sti350zguy
Member#: 62823
silver/Silver
nothing out of the ordinary. that it why we think it is someting to do with ignition.
Old 04-17-2005, 05:50 PM   #11
2phless
Member#: 69343
1998 TransAm cnvrtbl
If you are running launch control, the switch on your clutch might not be touching anymore (broken or misaligned), or the jumper that comes with the Remote switch might be loose.
2phless is offline   Reply With Quote
Old 04-17-2005, 06:49 PM   #12
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
could be a vacuum leak somewhere, i had this problem a lng time ago, turned out to be the hose to my gauge was leaking. one hell of a problem to figure out
vtecTHIS is offline   Reply With Quote
Old 04-18-2005, 01:04 AM   #13
sti350zguy
Member#: 62823
silver/Silver
launch controll is diconnected. We tested for leaks and have not faund any. I ran some 104 oct gas through it today on the street and it was reving all he way out up to 4th gear with no prob. I do not know if it will in 5th or 6th ( not able to get going that fast ). I did order a new coil and I am going to try swapping them out one by one and see if it cures the problem. Thanks every one for all your help!!!! keep it comming
Old 04-18-2005, 10:12 AM   #14
wile2k
Member#: 58444
'02 Z06
Millenium Yellow
Wow, your problem sounds a lot like mine. Reference here...
http://forums.nasioc.com/forums/showthread.php?t=753775
I'm going to pull my plugs and check those and maybe gap them down a little bit until I can get a new set here. Most frustrating problem I've had in a while.
wile2k is offline   Reply With Quote
Old 04-18-2005, 02:42 PM   #15
bboy
Member#: 56468
04 Improved STI
Dirty White
My first vote if AFR looks good.
Old 04-18-2005, 03:46 PM   #16
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Does your boost drop when it happens?
TopSpeed is offline   Reply With Quote
Old 04-18-2005, 04:05 PM   #17
wrex03
Member#: 29963
04 sti
Check to see if you didn't break your TGV when installing the inlet. If you have a delta dash you can see if they are opening.
My car ran fine until rpms got upto around 5500 and then it would just stop.
wrex03 is offline   Reply With Quote
Old 04-18-2005, 05:11 PM   #18
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
This problem is popping up more and more. I have three cars here that do the exact same thing. Right around 6000 rpm its as if there is a rev limiter kicking in. No matter what I do the car will still do this. Even stopped in neutral.. All cars are 04's. All have big turbos and all have larger injectors.
I have swapped Utecs from cars that are not doing this with no luck. This happens at 4psi or 25 psi. Any AFR from 10 to 1 to 13 to 1. Any amount of timing. It is not tuning. I believe its ignition cut out of some sort. If you run on the stock ECu the problem disapears. I called TXS and they had not heard of this. I have never seen this on 05's. Only 04s. I now know of 7 cars doing this... I hope someone figures this out soon.
Clark
Kingpin is offline   Reply With Quote
Old 04-18-2005, 05:38 PM   #19
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
it may not be connected, but is is enabled....
if it is, it thinks you have the clutch engaged 24/7
DISCOPOPE is offline   Reply With Quote
Old 04-18-2005, 07:16 PM   #20
x99percent
Member#: 27108
2004 STi
2004 A4
Last I saw, the launch control was disabled in his UTEC's parameters.
x99percent is offline   Reply With Quote
Old 04-18-2005, 10:23 PM   #21
sti350zguy
Member#: 62823
silver/Silver
you guys are all being a great help!!!! thanks!!!!
Kingpin.. my car is fine in neutral 1st 2nd and 3rd. Heavy load is when it happens. I did get a missfire code yesterday. I have a new coil and i am going to put it in that cylinder and see if it fixes it.. I will keep you posted..
Car will not enter test mode. jmikolich Newbies & FAQs 19 07-09-2010 01:59 AM
My car will not go past 5k RPM's VBwrex13 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 03-23-2009 06:36 PM
Help! Car will not hold any RPMs Strtwre Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 12-12-2008 05:16 PM
Wont go over 2K RPMs!??! ATXImpreza Normally Aspirated Powertrain 4 03-14-2006 11:00 AM
black smoke and i cant go over 2700 rpm subiekid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-09-2003 10:40 PM
