Old 04-16-2005, 02:17 AM   #1
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
Default best (lightest) NOT underdriven crank pulley
like the title says. which is the lightest stock sized crank pulley? did a search, found no actual specs. (probably did it wrong but oh well)
svek is offline   Reply With Quote
Old 04-16-2005, 07:27 AM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
i think the perin one, then the mr josh one
Shane
PARANOID56 is offline   Reply With Quote
Old 04-16-2005, 09:18 AM   #3
sebtarta
Member#: 82883
2006 2.5i Wagon
'72 Nova Turns & Stops
sebtarta is offline   Reply With Quote
Old 04-16-2005, 10:39 AM   #4
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Originally Posted by sebtarta
I agree!!
Best price too!
omahasubaru is offline   Reply With Quote
Old 04-16-2005, 07:03 PM   #5
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
Perrin Pulleys.... can't go wrong for 125 bucks.
Caplin 2.5 is offline   Reply With Quote
Old 04-16-2005, 09:39 PM   #6
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
Sonin was great too.
Crash477 is offline   Reply With Quote
Old 04-16-2005, 10:14 PM   #7
WeloReX
Member#: 78322
2003 Impreza WRX
WR Blue
Agency Power has one out that Rallitek is selling on special for 99.00 bucks and I think they weigh the same as the Perrin but they have that nice billet look...
WeloReX is offline   Reply With Quote
Old 04-16-2005, 10:20 PM   #8
WeloReX
Member#: 78322
2003 Impreza WRX
WR Blue
I just did a quick search, the Perrin is 1.2 lbs the Agency Power is 1.1 lbs. Maybe if the Perrin logo is shaved off it would be the same...
Old 04-16-2005, 10:22 PM   #9
svek
Member#: 82259
1999 impreza 2.2L
mr josh pulley looks like the way to go. 1.2 lbs, 90 shipped. what a deal.
Old 04-16-2005, 11:07 PM   #10
OneOBS
Member#: 63076
2004 Outback Sport
Red!
I bought and paid for mine almost three weeks ago and still haven't got it. Buyer beware.
OneOBS is offline   Reply With Quote
Old 04-17-2005, 01:36 AM   #11
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Sometimes he takes awhile to respond.
I chose Mr. Josh's pulley after holding it next to a perrin pulley. I honestly think it's made a little better.
BlkTS02 is offline   Reply With Quote
Old 04-17-2005, 09:39 AM   #12
Iceman12321
Member#: 71034
2001 Outback Ltd.
Sedan - White
would a aftermarket pulley, such as Mr. Josh's be an easy, good, first mod to a NA car? what sort of improvements are there?
Iceman12321 is offline   Reply With Quote
Old 04-17-2005, 09:39 AM   #13
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Mr. josh is top notch. I did a GB on them ahile back.Have many different scoobies with them still runnin' great. Been over 2 years.
Old 04-17-2005, 10:39 AM   #14
OneOBS
Member#: 63076
2004 Outback Sport
Red!
I got a note this morning with a FedEx number. Paying with Paypal and then having the part get shipped three weeks later is completely unacceptable. It feels like you're sending your money into a black hole.
I like the product. That's why I bought it. If you're going to run a business, there are certain expectations that need to be met. Had he responded immediately and said it would be 2-3 weeks before it was shipped, that would have been OK, but there was nothing...
Old 04-17-2005, 01:18 PM   #15
svek
Member#: 82259
1999 impreza 2.2L
according to his site:
-better throttle response and engine braking
-average gain of 8hp at the wheels
i would say that is worth $90. and with all power mods they work together. the more you put on the more power you get out of each part.
Old 04-18-2005, 02:48 AM   #16
anonymous_wolf
Member#: 57780
2000 RS sedan, GC6
Blue Ridge Pearl
i doubt there's 8 whp gain from light weight pulley along, but the engine does rev up quite a bit faster in first and second gear (and first and second gear only, i timed it...)
btw, is it just a myth or it's really bad to have both the light weight pulley and light weight flywheel?? and why is so bad?
anonymous_wolf is offline   Reply With Quote
Old 04-18-2005, 08:17 AM   #17
Nicklbrso
Member#: 44887
00 GC6
Just a myth.
Nicklbrso is offline   Reply With Quote
Old 04-18-2005, 11:35 PM   #18
kulaid982
Member#: 65337
2004 Outback Sport
Well, not neccessarily a myth...
In the reading that I've done, doing a lightweight pulley and lightweight flywheel is just fine for our boxer engines, as we have a nice short crankshaft. However, when you've got a V8 which has a longer crankshaft, having lightweight at both ends (pulley and flywheel) can allow for some funky vibrations that are not neccessarily good for your engine.
Bottom line, on our cars you should be fine doing both because the crankshaft is too short to allow for those funky vibrations to occur, but if you have a bigger engine with a longer crankshaft, pick one or the other to be safe.
PS: I apologize for being too lazy to redo all the research I've done before to link to threads, but everything I read was either here or at the Cobb forums, so happy searching if you don't believe me!!!
kulaid982 is offline   Reply With Quote
Old 04-19-2005, 01:40 AM   #19
davidji
Member#: 59980
03 Forester
1. Anyone done G-Tek or dyno on just the lightweight pulley vs. stock?
I didn't expect much from it (and not 8whp). If it actually did 8whp for example, I'd likely do it. Even if your results are for an underdriven pulley, I'd like to see 'em.
2. Do vibrations go up? Aren't you giving up your harmonic balancer? Does that shorten main bearing life? Void engine warantee? I guess at 30k miles, I don't have much of that left anyway (IIRC the warantee is for 36k miles).
I wasn't considering the pulley, but if people have actually seen significant power gain, I would. I guess the way I saw it is in this case where the pulley would actually be cheaper to manufacture than stock, and saves weight, if it were a good thing FHI would build the cars that way. If I'm wrong, let me know.
davidji is offline   Reply With Quote
Old 04-19-2005, 02:42 AM   #20
quest
Member#: 42402
- Finder of Porn
-Bringer of tears...
sonin pullies are mr josh pullies
quest is offline   Reply With Quote
Old 04-19-2005, 02:57 AM   #21
anonymous_wolf
Member#: 57780
2000 RS sedan, GC6
Blue Ridge Pearl
not really, my friend has mr josh and i have the sonin from crash477
sorry to say this but mr josh is ALOT better built. ie, installation of mr josh was a breeze, slide right in and fit perfectly.
for sonin, we had to use the bolt to force the pulley into place.
as for the performance gain.
i did a little stop watch 0-100km/h test. seems like there's about 0.2-0.4 sec reduction in the 0-100km/h time after i installed the pulley and Grp N tranny/ engine mounts.
Unorthodox Lightweight Racing Crank Pulley petrakov08 1993 - 2001 Impreza Specific Parts 10 06-05-2010 02:06 AM
fs: obx underdriven crank pulley thisisthenewsic SCIC Private Classifieds 6 12-26-2009 05:45 PM
FS: GFB underdriven crank and alternator pulley kit shikataganai Private 'For Sale' Classifieds 10 05-09-2006 11:14 AM
WTB: Lightweight Crank Pulley, non-underdriven e_a_olson NESIC Private Classifieds 3 03-12-2006 10:26 PM
WTB: lightweight crank pulley non-underdriven skunkfifty MWSOC Private Classifieds 0 02-06-2006 05:44 PM
