Old 04-16-2005, 03:57 AM   #1
michyous
Member#: 84817
Unhappy Reverse Lights Dont Turn On - Help
Hi All,
I have a '99 Liberty, which would be equivalent to an '00 Legacy.
I have a funny situation when I put it in reverse...... the number plate lights are turning on. If I turn the headlights on and the car is in reverse the number plate lights turn off .
During this time the reverse lights never turn on .
Its manual and I have been reading other posts but nobody has mentioned the number plate lights so could it still be the switch at the transmission?????
I have a pic of the location of the switches "I Think"
Please help!!!
michyous is offline   Reply With Quote
Old 04-16-2005, 08:20 AM   #2
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Well first off have you checked the fuses? In your body style the back-up lights are on their own fused circuit. You should find a fuse for them under you dash in the fuse panel.
Otherwise you're referring to the neutral position switch which also activates back-up lights when shifted into reverse. Itís on the drivers side of the transmission. You may want to pop your hood and look down that side of the tranny just to ensure everythingís hooked up and not melted or something.
xcntrk75 is offline   Reply With Quote
Old 04-16-2005, 11:57 AM   #3
michyous
Member#: 84817
Question
Yep at first I thought it could be the fuse, but the fuse is fine.
I have checked the bulbs and what I believe the switches are cos there are plenty around. All looks well
How can I test the switches?
Old 04-16-2005, 05:30 PM   #4
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
After thinking about this a little more, how in the hell did you end up with this problem?
The back-up lights and license plate lights are probably on different circuits. So why would the indicators come on when in reverse?
You may want to look around in your trunk/hatch and see if one of the harness pigtails got crimped somewhere. Maybe while hauling a load? Otherwise pull the wiring diagrams for you model (techsubaru.com) and trace it out...
Old 04-16-2005, 07:45 PM   #5
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
i think xcntrk is on the right track, that is the only way that is possible it seems, is if the wires in the back somehow got crimped, cause the reverse lights are triggered by the reverse switch sensor, the only place those are near each other is in the rear wiring.
Ben
Old 04-16-2005, 10:54 PM   #6
michyous
Member#: 84817
I thought the same thing. I know they are on different circuits.
See the problem started when I installed a new deck. After I did the install and closed everything off the dash illumination wire hit a ground.
I snapped it and pulled it all apart again and found that the elec tape I used came unstuck. So I changed the fuse but my dash lights are out so I have to wait for subaru to get the Illumination Control Module for me which will cost me $130, wreckers wanted $145
But ever since then I have had this other weird problem with the reverse and plate lights ... could be coincidence!
Reverse lights dont turn on MJBrowny21 Transmission (AT/MT) & Driveline 6 03-22-2010 05:25 PM
cruise control lights dont turn on. scoobynoobEMT Electrical & Lighting 4 02-04-2010 10:58 AM
Reverse Lights Not Turning On...Fuse is Fine. XanRules Electrical & Lighting 3 05-18-2009 12:24 AM
Reverse light dont work and CEL's Twiztidunreal Electrical & Lighting 1 08-06-2008 12:50 PM
reverse lights won't turn off. asherbo Vancouver Impreza Club Forum -- VIC 8 02-24-2007 02:07 PM
