Old 04-16-2005, 03:39 PM   #1
legacyace
Member#: 84364
1997 BG-5
Ones Black and Ones White
Unhappy Check Engine Light goes on all the time.
I've got a 1995 2.0L Twin Turbo Legacy GT.
Of recent the CEL come on, with code 22, which relates to the Knock Sensor. I check it out and the knock sensor was damaged, so replaced it and that fixed the problem.
However, while replacing it, the intercooler and top inlet manifold was taken off, to create space for the sensor to be replaced but, in the proccess the setting for the throttle sensor was tampered with, this now created a new problem, the CEL comes on and off showing code 31(Abnormal voltage input entered from throttle sensor).
Does any one know how i can adjust the throttle sensor position to it right place.
legacyace is offline   Reply With Quote
Check Engine Light comes on, whats the problem? sanovichleo Service & Maintenance 7 04-19-2005 05:56 PM
does the check engine light come on when u need to go in for maintenance? garie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-11-2004 07:14 AM
Why did the Check engine light comes on when i install the Blitz Intake? Boosted Wagon STi Forum Archive 17 06-20-2003 09:08 AM
replaced the T and the hose and the restrictor now the check engine light comes on scoobydoo02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-04-2002 10:21 PM
