Old 04-16-2005, 06:15 PM   #1
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Default Speedometer Help Needed…
I finished my WRX engine and transmission swap and can’t seem to get my speedometer working. I know my VSS is working and have the proper speed signal at my ECU as confirmed by my OBD-II reader and multi-meter (0v – 5v alternating). My problem is with the difference in wiring at the combination meter between my 98 Legacy, and that of my WRX VSS.
My existing speedometer gauge originally had a 2-wire VSS direct feed (from my old tranny), then sent the speed signal output to my original ECU as seen here:
I’m now running a WRX transmission which is using the 3-wire VSS (1-power, 1-ground, 1-speed signal). I have the speed signal directly feeding my new ECU and connected to what use to be the output wire in the diagram above. Obviously this isn’t working. The original two VSS wires aren’t hooked up to anything either. I tried feeding the speed signal to each of these wires individually with no luck.
WRX VSS & Combination Meter wiring as a reference:
Anybody who has any advice or input please respond as I’m at my wits-end.
xcntrk75 is offline   Reply With Quote
Old 04-17-2005, 06:06 PM   #2
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Anybody swap transmissions over and get their speedo working?
All comments appreciated…
Old 04-17-2005, 10:44 PM   #3
agterlik
Member#: 41626
SPB We make people
quit teh internet
Wouldnt you want to hook the signal going from the ecu to the input signal on the combination meter?
agterlik is offline   Reply With Quote
Old 04-18-2005, 07:26 AM   #4
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Beats me, that’s why I’m asking…
Seriously though, if I were to hook it up as my original was, I would feed the speed signal from the VSS to my speedometer, then feed the output to my ECU. I haven’t tried this yet mainly because my speedo wants a two-wire input from the VSS and my new WRX one is only one-wire.
Anybody….thoughts…comments…
Old 04-18-2005, 11:46 AM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
the second wire is power to make the sensor work
i would try tranny->ecu->pin 5
edit: now that i think abou it
use the 98 speed sensor
tranny->speedo->ecu
Help needed with coilover installation - VA (Woodbridge/Manassas) dc.fireman Mid Atlantic Impreza Club -- MAIC 24 06-06-2010 12:04 AM
Speedometer off.. need help! Drake13 Electrical & Lighting 11 07-14-2008 11:18 PM
speedometer help 25rsESP Electrical & Lighting 2 01-10-2007 07:15 AM
speedometer help winorlose2221 Newbies & FAQs 3 08-04-2006 01:52 PM
speedometer help winorlose2221 Texas Impreza Club Forum -- TXIC 0 08-04-2006 01:54 AM
