Old 04-16-2005, 07:21 PM   #1
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
Default need Info on Ver6 fuel control
Does the Ver6 have a Fuel pump controller? I've looked thru my wiring diagrams and I don't see one. But I'm running rich enough to bog my car down. Just trying to cover all my bases.
-Jorj B
HeMan1320 is offline   Reply With Quote
Old 04-16-2005, 07:43 PM   #2
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
nope no FPC
Scoobie Steve is offline   Reply With Quote
Old 04-16-2005, 09:09 PM   #3
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
Any ideas why it would be running so rich? I officialy have all the proper sensors (Thanks to Grade A Subaru) and a 80mm MAF housing. I'd be running lean if I had a vacum leak. So what's next on the list for running rich? oh yeah, I'm not getting a CEL.
Old 04-16-2005, 09:15 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
whats your fuel pressure?
Old 04-16-2005, 10:22 PM   #5
Scoobie Steve
Member#: 2289
What maf housing and sensor.....is it a Ver 6 housing?? Those are the only things that will make you run very rich. Temp sensor should throw a code if its bad. Fuel pressure problem is pretty unlikely but possible.
Old 04-17-2005, 02:44 AM   #6
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
running the 99RS MAF and the Big Perrin Housing...which is 80mm. Should I go ahead and invest in the Ver6 housing?
Old 04-17-2005, 01:46 PM   #7
Scoobie Steve
Member#: 2289
I am concerned the MAF sensor isnt sitting correctly in that housing, any pics? Did you measure the inside diameter of the housing?
Old 04-17-2005, 11:48 PM   #8
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
yeah I measured it and it's exactly 80mm. But I have been browsing some UK forums and they are say 99-00 is 90mm. And that would explain alot. Running rich and also the high idle. with no CEL cuz nothing is really wrong...per se
Looking to Purchase a 06 WRX Need some Info on SoCal Fuel Economy and What to look 4 SentientByDesign Newbies & FAQs 30 11-18-2009 03:20 PM
Need info on fuel pressure regulator on 2002 WRX mathroch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-26-2007 08:56 PM
need info on delaying "that time" w/birth control pills.. alacrity024 Off-Topic 32 06-18-2004 01:18 PM
PE fuel pump dies - POS - need info on supra pump alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 02-20-2002 08:25 AM
Need Info on Ground Controls Kilumanati Brakes, Steering & Suspension 3 10-29-2000 02:55 PM
