Welcome to the North American Subaru Impreza Owners Club Sunday November 23, 2014
Old 04-16-2005, 06:29 PM   #1
scubyduby
Member#: 66405
Default Urgent Help Needed!
I am calling out in desperation as I have a problem I cannot fix. I have just installed a new set of Pinks, (injectors) and one of them will NOT stop leaking. and when I say leaking I mean spraying. I have tried and tried and cannot fix it. I tried replacing it with one of the oem ones, it to now leaks, I put the injector on, rebolt the fuel rail and crank the car, and it jsut seems to unseat itself, and fuel sprays from between the rail and the injector, any ideas? please I am in dire sraights.
scubyduby is offline   Reply With Quote
Old 04-16-2005, 08:23 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
sounds like you are missing an o-ring or you doubled them up.
Jay
munkis is offline   Reply With Quote
Old 04-16-2005, 09:10 PM   #3
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
make sure u didnt pinch any o rings, u should get new O rings if u are having this issue
also, use vasaline to luve them before inserting into the rail
YaZahX is offline   Reply With Quote
Old 04-17-2005, 02:03 AM   #4
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
The rubber oring seat dealie could have also fallen off. If the injector rotates freely this is more than likely what has happened.
Zephyr is offline   Reply With Quote
Old 04-17-2005, 03:18 PM   #5
scubyduby
Member#: 66405
The o-ring is still on the injector, by double them up do you mean the o ring from the stock injector could have come off in the rail? Gonna try the lube thing and see if it works, I am afraid the rail is damaged though.
Old 04-17-2005, 04:57 PM   #6
scubyduby
Member#: 66405
Cool Found It!
ok, I went back out and just happened to look under the car, and see a rubber ring, not the little o ring mind you one much thicker and larger in diameter, so I pull the rail again and look into the openings where the injecors enter the manifold (not sure of the technical term) and that was where it went sure enough, stuck it back in, reattached the rail and vola, No leaks WOOT. Thanks to everyone who replied!
Old 04-17-2005, 07:13 PM   #7
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Excellent! I'm glad you were able to solve the issues.
Z
Old 04-18-2005, 12:00 AM   #8
scubyduby
Member#: 66405
yeah me too I was so happy I was about to dance... then I remembered i was white, southern, and have no rythm so I settled for yelling really loudly
Urgent! help needed Urgent! iamrazor Legacy Forum 20 01-02-2006 04:43 PM
Urgent Help Needed on Truck Flood ! Im'Pat'za Interior & Exterior Modification 3 04-01-2001 11:23 PM
Urgent help needed with 91 Acura Intake. munkis General Forum Archive 12 01-01-2001 04:37 PM
Urgent Help Needed for Buying Kumhos! VALENTA New England Impreza Club Forum -- NESIC 1 06-12-2000 12:37 AM
Urgent Help Needed about Kuhmo Tires VALENTA General Forum Archive 3 06-11-2000 02:52 PM
