Old 04-16-2005, 07:36 PM   #1
dcwrx2
Member#: 69005
'04 4EAT Wgn
Default Drain and refill A/T tranny oil in-between each full tranny oil flush?
I was told it is recommended (especially for 4eat) to drain and refill tranny oil in-between each factory scheduled tranny oil flush, because it is healthier to the 4eat trans, and also drain from tranny oil drain plug will only give me 4-5 quarts (instead of all 10 quarts) so it is not messy, economic to refill with 4-5 quarts fresh tranny oil, and as simple as regular engine oil change.
Is anyone doing the same thing? I wanna know if draining A/T tranny oil from the drain plug will really drain out 4-5 quarts rather than 8-9 quarts...
dcwrx2 is offline   Reply With Quote
Old 04-16-2005, 07:47 PM   #2
orndog
Member#: 34670
2013 No gears!
Saltine American
It won't drain the torque converter or trans cooler, so no, it won't drain all of the fluid.
orndog is offline   Reply With Quote
Old 04-16-2005, 10:40 PM   #3
dcwrx2
Member#: 69005
'04 4EAT Wgn
Does stock 4eat WRX have trans cooler?
So the max amount I can drain thru the drain plug is how much?
Old 04-16-2005, 11:11 PM   #4
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Yes, all autos have coolers. Its like 4.5 quarts or so.
OneOBS is offline   Reply With Quote
Old 04-17-2005, 03:32 AM   #5
dcwrx2
Member#: 69005
'04 4EAT Wgn
But ppl are saying if mod the torque converter to a high-stall speed one, then need a trans oil cooler.... Do they mean to add an extra cooler, or replace the stock one with aftermarket one?
Old 02-24-2009, 12:53 PM   #6
slwmatc
Member#: 180757
04 WRX
Thumbs up Tc
The 02-05 wrx's come with the built in tranny cooler in duh radiator; however if ones was to upgrade the TC in the 4EAT then one needs to purchase an external tranny cooler to either mount in front of the A/C condensor; bypass the hoses from the tranny to ur new tranny cooler and plug up the old ones from the radiator; of course i have heard and seen AT subys using dual coolage from the stock radiator and the AM- tranny cooler; hope this helps.
slwmatc is offline   Reply With Quote
Old 02-24-2009, 05:06 PM   #7
dcwrx2
Member#: 69005
'04 4EAT Wgn
Wow this thread is old... ;-)
Yeah, after my last post, I did the TC (and VB) mod w/ an external Hayden ATF cooler. I'm running both cooler (Hayden + radiator-cooling) in my setup w/ Amsoil ATF.
It's been 70k+ miles on this setup and no problem so far. I did have ATF drain (4 Qts) & refill at every 30k miles.
Old 02-24-2009, 05:26 PM   #8
slwmatc
Member#: 180757
04 WRX
evry 30,000 mile, i thought it was 15,000?
Old 02-25-2009, 04:30 PM   #9
dcwrx2
Member#: 69005
'04 4EAT Wgn
You can rely on Amsoil's quality. 15k drain & refill is a bit overkill =)
Burning oil in between changes? Pinned Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-01-2009 10:43 AM
oil in intercooler maybe from synthetic oil? peonslayer Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 05-31-2006 06:38 PM
drain and refill ATF - need advice nosajh9 Transmission (AT/MT) & Driveline 0 09-22-2005 11:21 AM
Drain and refill on '98 Legacy L with 4EAT? shortlid Transmission (AT/MT) & Driveline 1 01-21-2005 10:45 AM
Draining and Refilling Power Steer Fluid 98kPa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-06-2002 01:34 PM
