Old 04-17-2005, 10:52 AM   #1
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
Default UTEC OLF Injector Flow Questions (Quick)
Greetings -
I've got a set of modded stock injectors that were flow tested at 43.5 psi and flowed 835-840 cc/min. I'm running open loop fueling and want to set the Injector flow parameter appropriately before I start tuning the fuel map. It's a 2.0L WRX with all the supporting mods.
1) Since 43.5 is the stock fuel pressure, is that what the 565cc STi injectors and 420cc stock injectors were rated at? (i.e., should I enter a value of 820-830 as the injector flow due to the results above). Obviously at 30psi of fuel pressure the injectors flow less (maybe 740?).
2) This parameter applies an offset to the 0% fuel column, but does it apply across the entire fuel map? 10-100% columns?
I searched a bit and read a bunch about the injector scaling, but can anyone answer these quick questions? TXS? Anyone...
Thanks in advance!
jetskizero is offline   Reply With Quote
Old 04-17-2005, 12:55 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
The OLF setting in the UTEC is an overall setting that effects all fueling points. If you set it to 830/420, it should start right up, unless that correction (almost 50%) is too large... I don't know how WRX's handle their fueling that low in the MAF voltage range. Might just throw a CEL complaining it's out of range, but it shouldn't just fail and not work.
I highly suggest you get the car tuned by a pro, though... that is a lot of correction and it very likely will need tweaking at individual points to run smoothly/correctly.
Old 04-17-2005, 01:08 PM   #3
StiDreams
Member#: 26315
07 Outback
Silver/Silver
You will also need to tweak some of the 0% fuel columns to get the fuel trims to be happy.
StiDreams is offline   Reply With Quote
Old 04-19-2005, 12:57 PM   #4
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
I've got an OBDII scanner that can read the fuel trims coming in the mail, so I'll definately check and adjust the 0% column. The 0% column fuel adjustments ONLY adjust that column correct (i.e., they are NOT like the injector scaling which applies across the board)?
I have a tuned stage 4 with a great set of fuel maps, but I'm swapping turbos and injectors so all bets are off. I'll learn alot though...
Old 04-19-2005, 01:00 PM   #5
StiDreams
Member#: 26315
07 Outback
Silver/Silver
0% is just for the 0% column.
Old 04-24-2005, 08:31 AM   #6
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
Using the stage four map dictates that you use the STI injector size, NOT the wrx injector size in the OLF scale, since the map was originated using the STI injectors,:ie; 820/565. That will give your UTEC a smaller correction factor and make tweaking a little easier but you'll still have to modify the 0% columns.
wrx plus is offline   Reply With Quote
Old 04-24-2005, 02:26 PM   #7
x99percent
Member#: 27108
2004 STi
2004 A4
That makes no sense.
Sure, he can use the Stage 4 map for timing, but when it comes to the fuel map, all bets are off.
The best bet is zero out the fuel map, scale the injectors as needed for to get the fuel trims close to zero, then adjust the scaling numbers up or down equally to get the WOT fueling close to where he wants it to be. Once that is done, start tweaking the fuel map.
x99percent is offline   Reply With Quote
Quick injector Flow question drewwrxrogers Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-09-2007 07:13 PM
Utec OLF and STi Pinks coyote73176 UTEC 8 11-11-2006 06:54 PM
Modified injectors flow patterens question?? greysave Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 10-23-2005 02:25 PM
UTEC Q: effects of changing OLF injector scaling happasaiyan Engine Management & Tuning 24 12-14-2004 11:38 AM
sharing of utec OLF fuel maps ride5000 Engine Management & Tuning 5 07-21-2004 02:09 PM
