Old 04-17-2005, 12:55 PM   #1
staticfritz
Member#: 66934
2004 JBP FXT
2002 cammed OBS - RIP
Default nasty idle....searching?
i rebuilt an ej25 last weekend to go in my car.
spicy cams, new valvesprings, light flywheel, cai, el-headers, cometic gaskets
i'm getting a real nasty idle,it's spends a lot of time searching (from ~500-1000rpm) and i get crazy vibration. as soon as i touch the throttle, the vibration goes away. crusing at 3-4krpm, the shiftknob is vobrating a fair bit. other than that, car drives fantastic, but what to do about my idle?
is it possible the timing belt is off by one tooth on a cam sprocket? (i'm 95% sure it's not off, but...?)
i'm running really rich right now too. matt suggested hotter plugs (93 octane)...could this be the source of my problems?
any suggestions or help form those of you more experienced in the n/a stuff would be great.
staticfritz is offline   Reply With Quote
Old 04-19-2005, 09:57 AM   #2
staticfritz
Member#: 66934
2004 JBP FXT
nobody?
Old 04-19-2005, 10:26 PM   #3
AWDsub
Member#: 56303
2010 Legacy GT
With your set up you can expect a little rougher idle. But are you sure that you dont have a bent valve? Try a compression test and of course, check your PCV valve.
AWDsub is offline   Reply With Quote
Old 04-19-2005, 11:33 PM   #4
staticfritz
Member#: 66934
2004 JBP FXT
the intake manifold cam off my old engine which was running perfect, so i'm doubtful about the pdv....but maybe i do have a valve issue...hmmm
compression test it is...
So I have searched for days.(seriously) Hi Idle after 2.5 swap turbored02 Subaru Conversions 4 06-16-2009 08:05 AM
Rough idle when warm, 01 RS, yes I searched ;) rogue Normally Aspirated Powertrain 6 05-13-2009 06:39 PM
Searched! P0442 code with Rought idle.... erickrm Newbies & FAQs 6 06-25-2008 01:18 PM
TD06 18g install and idle search blue m&m Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-28-2006 11:21 PM
some help please idle issues(I've searched, trust me) Lavery Normally Aspirated Powertrain 11 11-14-2005 10:26 AM
