#1 |
Member#: 70810
SCIC
Vehicle:07 impreza STi Jizz White.facial anyone? |
i decided to finally upgrade to v.17 since my car kept stalling on me with v.16. v.17 is not working right with my car. 1st-3rd gear my car sputters a tad bit around 3500RPM and then a lot worse at 5000RPM. i did a few WTO and the outcome was still the same. anyone witness this problem?
#2 |
Member#: 81630
South East
i had the same r.esults for the most part on the update. as far as the stalling i cant help you though
#3 |
Member#: 70810
SCIC
ok i figured it out. i ran the same version realtime map(v1.17) over the base map(v.1.17). i used the AP to reset the ECU so i would just run the base map and all is fine. took it for a few WOT runs and my car is good to go.
i use to run the same version realtime maps over base map with previous versions and i never had a problem. so hopefully this helps you cobb 2.5 users. |
| Thread Tools | |
| Display Modes | |
| Is anyone running a EBC with Cobb stage2.5??? | brandon_bxtr | Factory 2.0L Turbo Powertrain | 6 | 07-26-2005 10:04 AM |
| COBB Stage2.5 | SubWRX2002 | Factory 2.0L Turbo Powertrain | 14 | 05-29-2005 06:50 PM |
| Cobb Stage2... 10psi? | GeoT100 | Engine Management & Tuning | 19 | 03-10-2004 11:01 PM |
| fs: cobb stage2 ecu for swap.. | WRX Jim | Mid Atlantic Impreza Club -- MAIC | 5 | 10-12-2003 11:35 PM |
