Old 04-17-2005, 04:23 PM   #1
tsubaru02
Member#: 79628
2003 wrx ver 7 swap
mingnight pearl black
Default would a uppipe leak cause a performace loss
i have a uppipe leak would this cause a performance loss or no,also would it hurt my motor please help
tsubaru02 is offline   Reply With Quote
Old 04-17-2005, 04:35 PM   #2
shyguyk27
Member#: 39308
SPR
It would certainly be hurting the performace of the car. I don't see it causing serious damage. I had a leak not to long ago and it threw my car into limp mode.
shyguyk27 is offline   Reply With Quote
Old 04-18-2005, 02:00 AM   #3
tsubaru02
Member#: 79628
2003 wrx ver 7 swap
what is limb mode
Old 04-18-2005, 06:03 AM   #4
ncarn8
Member#: 71419
limp ghome mode is a mode where the car has sensed a problem and alters its settings, scales everything back like boost and timing to get the car home safely. Some biger engines have features where they rotate which cylinder fires to cool it if it has overheated, until you get it to a garage and fix it.
To answer the original question, yes a leak will cause a performance loss. how much depends on the size of the leak. a small leak, you may not notice the difference. If you have experienced a noticable loss, its probably something else or a combination of things. if it has a gaping hole in it then yeah of course its gonna run like crap.
ncarn8 is offline   Reply With Quote
Old 04-18-2005, 08:20 AM   #5
nfx
Member#: 42960
GC8 wrx
blck
uppipe leak would make car laggy down low without effects on top end
it would not hurt the motor
if its big will also cause idling problems
nfx is offline   Reply With Quote
Old 04-18-2005, 12:37 PM   #6
wgknestrick
Member#: 32576
04 STI
I know for a fact that pre turbo leaks will hurt spool and top end power.
wgknestrick is offline   Reply With Quote
Old 04-18-2005, 12:41 PM   #7
tsubaru02
Member#: 79628
2003 wrx ver 7 swap
idle cool no problem its not that lound but i can hear it and i dont like it and i cant really find it its by the uppipe that a shop put in thank for all of the in put
What would an exhaust leak between the uppipe and turbo cause? The Reaper 975 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 03-23-2006 05:18 PM
can an uppipe leak cause my car to feal sluggish? vapore0n Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-18-2003 10:17 AM
Uppipe leak.. boost loss? Big Turkey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-16-2003 06:36 AM
steering fluid leak caused by uppipe heat? wylie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-06-2003 02:28 AM
Would a small intake leak cause a CEL? Concillian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-07-2002 11:57 PM
