Old 04-18-2005, 02:05 AM   #1
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
Default tried to search but...yeah
instead of dealing with all the wiring mess of a JDM sti swap, could I just get the closed deck ej20 block and put my 99 SOHC heads on it and run the factory wiring with aftermarket fuel control such as an S-AFC and turbo?
now...from workin on honda's, I know S-AFC is a garbage solution to fuel delivery but I guess I am just using it as an example for fuel control.
civic2scooby is offline   Reply With Quote
Old 04-18-2005, 07:55 AM   #2
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
you could but from what I know the 99's are MAP making them a lot harder to aftermarket turbo and control with a S-AFC. I have heard the 98's DOHC MAF engines are a lot easier to use piggybacks.
A lot of people around here prefer swaps because it's cleaner and saves you a lot of money down the road...
benjaminetanyahoo is offline   Reply With Quote
Old 04-18-2005, 11:52 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
prolly belongs in aftermarket
eh.. 2.0 block +99 heads + stock USDM WRX injectors(blue) +emanage isn't too bad a solution as ghetto swaps go
you need the timing control as much if not more than the fuel control
Old 04-18-2005, 12:47 PM   #4
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
what about 2.0block 99 heads usdm wrx injectors and Link ecu
Old 04-18-2005, 12:48 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
even better
Old 04-18-2005, 04:13 PM   #6
Charge
Member#: 3313
I thought 99's were MAF's. 00-01 were the first MAP's. 98's are MAS, which is basically a MAF, right? It's just that the 99's were the film sensor type, that made them more susceptible to damage via contamination or vibration, I thought.
Charge is offline   Reply With Quote
Old 04-19-2005, 02:05 PM   #7
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Depends on how much boost you want to run. I've got SOHC RS heads on an STi shortblock and an S-AFC, running 7 psi boost, and it runs great. Timing control on the stock ECU was able to handle it.
jey is offline   Reply With Quote
Old 04-21-2005, 01:23 AM   #8
civic2scooby
Member#: 78658
2005 LGT Limited
Black/Black
exactly what I needed to know...I only wanna run like 7psi for right now on the scooby. I have been building up turbo hondas for a while, but I am not quite familiar with the subarus yet so I wouldnt be doing any large budget for this I just want some descent power and a fun car to drive...dont need to boost it to like 20psi...(yet)
He tried to rob me. Yeah, that's it... Rob me!. chapstien Off-Topic 29 02-09-2010 09:41 PM
trying to search but couldn't find it rally school madmaxwrx Mid West Subaru Owners Club Forum -- MWSOC 2 03-25-2009 11:01 AM
Tryed a search but? Does the STi R180 come with a LSD? 2002WRXSTi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 08-15-2004 11:38 AM
Man, I tried to search but this is hopelessly WTLW Snoopy Off-Topic 10 04-07-2004 03:08 PM
Using the clock 12V for a few items...tried to search, but it wouldn't work... Kwyjibo Electrical & Lighting 3 12-03-2003 01:03 PM
