Old 04-18-2005, 02:07 AM   #1
ScoobyRS-t
Member#: 85324
2005 WRX
Cool 2000 Subaru 2.5RS Turbo Set-up :)
For everyone out there with your RS-T's i was wondering what you thoughts are on this setup..
SR20DET turbo from 99' silva
Wrx up and down pipe's 2.75
Walbro Fuel Pump with STi injectors
Borla SS Header
Unorthox Racing Pullies
Fidonza Aluminiun lightweight flywheel with Stage 2 clutchmaster clutch
Apex' Boost Controller with HKS Turbo Timer
WRX intercoller and Greddy BOV
With either Greddy Evo 2 exhaust or Apex N1 cat-back, i like the greddy has a throatier sound and seems to be better quailty since my N1 the muffler welds cracked...
I haven't installed any of this yet its all in my room...was wondering if i could get any feedback, if anyone has similiar parts on their cars what type of results did u get, hp, torque,e/t, anything will do and if you have any reccomendations on getting anything else done to this to have it run quite smoothly at between 6-8psi, higher boost will come later on with the EJ257 block or the EJ22T block
ScoobyRS-t is offline   Reply With Quote
Old 04-18-2005, 02:16 AM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
first, do a search, all this info is covered.
secondly, i am not sure what turbo came on a SRT20DET(isnt it a SR20DET), so if you know what turbo it is specifically people will be able to answer that question better.
Ben
Old 04-18-2005, 02:31 AM   #3
ScoobyRS-t
Member#: 85324
2005 WRX
Ya it is a sr20det my bad typo a T28, all the piping and turbo it came off someone elses 2.5 turbo
Old 04-18-2005, 08:21 AM   #4
Aphex28
Member#: 11506
2015 WRX
Correct me if I'm wrong, but I think you're gonna need something to control timing. Like a APEXi ITC or something. And if you're gonna use the WRX up and downpipe... you're gonna need a legacy turbo or WRX crossmember
Aphex28 is offline   Reply With Quote
Old 04-18-2005, 10:41 AM   #5
Tats
Member#: 5692
WTF? YES! I am
better than you!
T28...might be a lil small for 2.5L. (Still prob OK for the low boost.)
STi injectors (if from USDM) will not fit..no way.
STI injectors from JDM..will have to be modded to fit the MY00 manifold. IIRC.
WRX up-pipe will not bolt up to the Borla Header, you will need a WRX exhaust manifold.
If you use the WRX manifold you will need a WRX or legacy turbo crossmember.
Look into SubaChad's pipes.
Also...you will need a J&S for safety AT LEAST. Unless you go stand alone engine management.
Really...read the FAQ'.
Tats.
Tats is offline   Reply With Quote
Old 04-18-2005, 01:10 PM   #6
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Probably need to have some way to retard timing as the boost goes up
kgb is offline   Reply With Quote
Old 04-18-2005, 08:41 PM   #7
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
Timing control
Fuel control
You might be able to get away with a spacer for now, but you'll want different pipes than the WRX ones because those cats are very in-effecent, and will cause lag. Get at least an up-pipe. Sell the turbo timer if you need money, because you dont need a timer, just sit in your car for an extra 5-10 seconds.
Oh, and get yourself some guages, you'll need to know what's going on.
tooocool49723 is offline   Reply With Quote
Old 04-18-2005, 09:45 PM   #8
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
wanna just get this?
t3/t4 turbo, up/downpipes, custom intake, oil lines,... etc..
http://forums.nasioc.com/forums/showthread.php?t=624573
cRayZee is offline   Reply With Quote
Old 04-18-2005, 10:49 PM   #9
balisticmotors
Member#: 81966
i have stock manifolds off of a wrx if anybody is looking for some
balisticmotors is offline   Reply With Quote
2000 subaru 2.5rs intake and functional hood scoop wildbill99 Normally Aspirated Powertrain 48 06-22-2015 02:39 PM
FS SoCal: 2000 Subaru 2.5RS 2.5 RS Sedan zion168 Private Vehicle 'For Sale' Classifieds 22 01-06-2014 02:39 PM
FS SoCal: 2000 Subaru 2.5RS 2.5 RS Sedan zion168 SCIC Private Classifieds 24 05-08-2009 06:27 PM
FS: 2.5rs turbo set up blueGC MWSOC Private Classifieds 0 06-07-2008 10:12 AM
FS: 2000 Subaru 2.5RS sedan RidinLow Tri-State Area Forum 1 01-12-2001 03:12 PM
