Old 04-18-2005, 03:35 AM   #1
iareben
Member#: 57946
2002 Subaru WRX
Question Low oil pressure?
I recently took my car to the track after getting my up-pipe and gagues put on only to get a measely 14.8 on the track. I believe it is because I have a very low oil pressure. When I start my car when it is cold out, and my oil pressure is higher, i run alot faster. But after my car has been running for awhile, and the pressure drops, I believe my HP does as well. I was wondering if there were any common causes of something like that or an explanation. The car has 45k miles and running synthetic mobile one oil. I have a utec stage 2 map, running at 1.3 bar boost, downpipe, uppipe, catback, short ram, and bov. Thanks
iareben is offline   Reply With Quote
Old 04-18-2005, 04:17 AM   #2
Rickyh
Member#: 40453
Please tell me you aren't trying to run 1.3 bar on the stock turbo. that is 19 psi. when you say your oil pressure drops, how low does it get?
Rickyh is offline   Reply With Quote
Old 04-18-2005, 04:23 AM   #3
iareben
Member#: 57946
2002 Subaru WRX
thats peak boost, i run 1.1 steady and its at 2 untill i accelerate, and then it only tops out at around 8 but normally is around six
Old 04-18-2005, 02:50 PM   #4
iareben
Member#: 57946
2002 Subaru WRX
and by peak i mean spike. I am running normally around 1.1 on a thid gear run. no help? '(
Drop in oil pressure / low oil pressure magicstop Newbies & FAQs 1 06-08-2009 02:23 AM
Low oil Pressure? Javier Factory 2.5L Turbo Powertrain 0 01-10-2006 04:27 PM
Low oil pressure Twisted STi General Community 5 12-28-2004 12:41 PM
Oil Coolers cause low oil pressure upon startup? kaos200 Factory 2.0L Turbo Powertrain 2 07-21-2004 02:22 AM
Low Oil Pressure MisterX Factory 2.0L Turbo Powertrain 29 12-06-2002 11:18 AM
Message Board Statistics All times are GMT -4. The time now is 01:44 AM.
