Old 04-18-2005, 11:15 AM   #1
C-daleRidr
Member#: 18074
2008 Speed3
Default MY00 front 02 sensor part number
Yeah, the subject. I need a part number for a MY00 front 02 sensor, mine seems to have gone bye-bye. I'm searching around here for it, I know it's here, but I haven't found it yet.
Thanks mucho.
C-daleRidr is offline   Reply With Quote
Old 04-18-2005, 02:34 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
22791aa00a
Oxygen sensor kit.
Tim Sanderson is offline   Reply With Quote
Old 04-18-2005, 04:28 PM   #3
ringe
Member#: 49998
2007 WRX CT Stg 2
I come up with 22690AA640 for the No. 1 O2 sensor with Alldata. Where did you get your part number?
ringe is offline   Reply With Quote
Old 04-18-2005, 04:56 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Off the box from subaruparts.com
It's subaru's #
Perhaps there was an upgrade.
Old 04-18-2005, 05:32 PM   #5
C-daleRidr
Member#: 18074
2008 Speed3
I found the same one that ringe came up with. Just wanted to verify it here before I order it. Thanks folks!
Old 04-18-2005, 07:18 PM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
You said you wanted to replace the front o2 sensor. Some people call it that. It's actually called an air fuel sensor. The part number you found(22690aa640) is the rear no.1 sensor for an ej251. The Part number I gave you(22790aa00a) is for the air fuel sensor.
Old 04-19-2005, 11:02 AM   #7
C-daleRidr
Member#: 18074
2008 Speed3
I'm trying to replace the sensor that throws a P0130, which looks to be the front a/f sensor that you're talking about. thanks for the clarification.
02-03 wrx front grill clips part number? djcttb Interior & Exterior Modification 17 12-14-2014 10:13 AM
02 Sensor part number. GC_Anthony Normally Aspirated Powertrain 11 03-26-2009 06:53 PM
02-03 front axle pin Part number jimtweet Private 'Wanted' Classifieds 1 12-19-2006 08:19 PM
why do 02 and 03 wrx's have different rear O2 sensor part numbers? Homemade WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-13-2004 08:53 PM
OEM Front O2 Sensor- Part Number? dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-10-2002 08:41 AM
