Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 04-18-2005, 11:35 AM   #1
oregonsixteen
Member#: 84932
1991 Legacy L AWD
Some kind of gold
OMGHi2U purge canister solenoid valve
what is it? and what does it do?
oregonsixteen is offline   Reply With Quote
Old 04-18-2005, 01:02 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
it's part of the evaporative emissions control system. It's a solenoid. It's connected to the charcoal canister that absorbs fuel vapors from the tank. When the engine is at a certain rpm and above, the ECU will open the solenoid, vacuum from the intake will suck the vapors out of the charcoal canister.
Legacy777 is offline   Reply With Quote
Old 04-18-2005, 01:04 PM   #3
oregonsixteen
Member#: 84932
1991 Legacy L AWD
Some kind of gold
so that's different from the pcv (purge control valve) right? i got a quote from the dealer, a replacement costs $89.63 (part only)!!!
i increased the RPM and found that the solenoid did open the valve, i.e. i could feel the vacuum suction come through although it is weaker than the suction at the intake. is this a binary device? i.e. full-open, full-close? or can it be partially-open/closed?
Old 04-24-2005, 12:43 AM   #4
oregonsixteen
Member#: 84932
1991 Legacy L AWD
Some kind of gold
Unhappy
Hi all!
I've confirmed that the solenoid is working. When I supplied 12 VDC to it, it operated normally. The resistance across its terminal is measured at 56 ohm which is within normal operating range.
I put a voltmeter across the incoming terminals with the engines running and I measured 12 VDC. When I connect the solenoid to it, it doesn't operate. When I connect a 12V light bulb (0.93 mA) across it, it doesn't light up. I'm baffled! Please help me!
Old 04-24-2005, 06:40 AM   #5
redwagon
Member#: 2181
2008 SpecB
From the ECU pinout it looks like there should be battery voltage on one of the terminals at any time the ignition is on. The other wire from the ECU will be at battery voltage when the solenoid is off, and drop to under 1V to switch it on.
redwagon is offline   Reply With Quote
Old 07-21-2005, 04:58 PM   #6
oregonsixteen
Member#: 84932
1991 Legacy L AWD
Some kind of gold
Thanks for all your replies. I ended up replacing the purge valve solenoid. But the Check Engine Lights won't go away. My local dealer says that's a "hard code" and needs a scan tool to reset. Disconnecting the battery won't work. Is that true?
Purge Control Solenoid valve? Synx Service & Maintenance 4 07-02-2008 05:40 PM
Broken Nipple on Purge Control Solenoid Valve 48mpg Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 02-24-2008 07:40 PM
Purge Control Solenoid Valve?? abosworth Normally Aspirated Powertrain 3 07-21-2005 04:20 PM
Code 35 purge control solenoid valve troubles theascen Service & Maintenance 2 04-02-2004 04:36 AM
Carbon purge canister check valve Steve E Normally Aspirated Powertrain 2 10-16-2000 08:44 AM
