Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 04-18-2005, 03:02 PM   #1
WRXinEffect
Member#: 19392
2006 Forester XT
Steel Gray
Default Is it okay to mount 235/40/17 tire on a 17/7.5 wheel??
Is it a bad idea to go beyond 225/45/17 for the stock 04 STi bbs wheel? I have a buddy who ran 23540/17s on the stockers and swore by it, but from everywhere I look it appears that tirerack, etc. warn against this set up... I would think that they'd be a bit loose???
WRXinEffect is offline   Reply With Quote
Old 04-18-2005, 03:53 PM   #2
BlkWRXWag
Member#: 31821
2015 DS WRX
loose?? I think you mean tight! I have a buddy who squeezed 245/45/17 onto those rims, so you should be fine.
BlkWRXWag is offline   Reply With Quote
Old 04-18-2005, 04:11 PM   #3
scooterforever
Member#: 55011
Depends on the manufacturer's specifications for minimum rim width. This will vary by tire type.
I'm not an expert, but I see it as a long term wear / safety issue. If you go under the specified rim width for a particular tire, then you are changing the flex point in the sidewall to a location that might be outside the manufacturer's intended flex area. This may negatively affect tire wear, and even the ability to maintain the bead.
I ran 235/40/17 on a 17x7.0 rim for 9 months. The manufacturer's minimum width on that tire was 8.0 inches. I was fine in the sense that I never lost a bead or had a blowout. But the problem is, everything will be fine until you actually have a problem. The last thing I want to take a chance on is loosing a tire bead on an off-ramp curve at 50 or 60 mph.
So... I'm still running my winter tires, and am going to say good-bye to my expensive 235 / 40 / 17s. Could I continue to run them without a problem? Maybe, but I just don't want to take the chance, being a full 1" outside of spec.
scooterforever is offline   Reply With Quote
Old 04-18-2005, 04:56 PM   #4
mistaboosta
Member#: 68722
I have the 7" wheels as well (Superleggera 7"x17"), would it be risky to use 225 / 40 / 17 tires on them?
mistaboosta is offline   Reply With Quote
Old 04-18-2005, 06:11 PM   #5
fliz
Member#: 30342
235/40/17 on 17x7.5 is done alot...you won't have any issues.
mista - Did you mean 225/45 or 225/40? A 225/45 is just fine on a 7" rim. I couldn't find any 40 series to see what they specify for rim width.
You can fit a tire on a narrower rim than recommended. Usually you will give up feel, lateral grip, and wear. Whether or not you give up enough to make the tire perform worse than a properly sized tire would depends on the tire and your driving style.
fliz is offline   Reply With Quote
Old 04-24-2005, 06:41 PM   #6
mistaboosta
Member#: 68722
yeah i mean 225/45 my bad sorry guys.
So 7" is no narrow for 225. that's nice than.
Old 04-25-2005, 01:27 PM   #7
krayge
Member#: 55651
2004 Impreza WRX
Platinum Silver
any chance someone could post a pic of some 235/45/17 on a 17"x7.5" rim? i'm curious exactly how much the overhang is. i'd liek to go with something a little wider then my 225's to help avoid curb rash and such on the rims. would 1/2" over the rim cause any major wear problems on the tire?
krayge is offline   Reply With Quote
Old 04-25-2005, 01:33 PM   #8
BlkWRXWag
Member#: 31821
2015 DS WRX
Every tire has a different width - for instance, a 225 Falken Azeni may be wider than some 235's, so how much "overhang" you have will depend on which tire you buy.
Old 04-25-2005, 01:37 PM   #9
fliz
Member#: 30342
What tire?
Different tires run different widths, even in the same size. For example, in 225/45/17, Potenza RE-070's are wider than Falken Azenis Sports which are wider than Hankook RS-2.
fyi, 7.5" rim is in the recommended range for most 235/45/17 tires.
Old 04-26-2005, 12:40 AM   #10
2ndGearFling
Member#: 64466
05, STI on green
I would say for the most part you can even fit a 245 on a 7.5 rim. Ive seen it done. Im sure you would be safe with a 235 in pretty much any tire you would want.
2ndGearFling is offline   Reply With Quote
Old 04-26-2005, 01:32 AM   #11
RogersWRX
Member#: 31617
2002 WRX Wagon
We fit 235/45/17 Hankook RS-2's on an Rota Torque 17x7.5 with absolutely no problem - zero overhang, looks great!. The Hankook's run a "true" 235, while the Falken's and Kumho's tend to run wider than advertised!!
RogersWRX is offline   Reply With Quote
Old 04-27-2005, 01:11 AM   #12
F1WRXRACING
Member#: 36370
235/40/17 I think you wanted to say..
I want to do the same on 17x7.5 Enkei RPF-1 wheels. Any pictures of them mounted on your Torques?
F1WRXRACING is offline   Reply With Quote
Old 04-27-2005, 08:24 PM   #13
Nightrunner
Member#: 69667
JGTC Cusco' STi WR1
Contemporary Hair Design
Subydude.com has those pics.
Nightrunner is offline   Reply With Quote
Old 04-27-2005, 09:15 PM   #14
RogersWRX
Member#: 31617
2002 WRX Wagon
correct.. 235/40/17 in the Hankooks S-R2
here are 235/45/17 in Kumho MX's
(please excuse my crappy camera phone pics! ; )
Also.. 225/45/17 in Falken Azenis 615's... can't see the rim as well in this shot.. All on 17x7.5 Rota's
Old 04-27-2005, 10:02 PM   #15
F1WRXRACING
Member#: 36370
Very nice. Thank you for the pics!
Old 04-28-2005, 11:05 AM   #16
krayge
Member#: 55651
2004 Impreza WRX
Platinum Silver
wow...i like those hankooks. thanks for the pics!
Old 05-24-2005, 12:50 AM   #17
HIREN
Member#: 51633
2013 GT-R
Just what I was looking for, looks like im going with 235/40 Hankooks RS-2s on my stockers. Thanks for the pics Roger.
HIREN is offline   Reply With Quote
Old 05-30-2005, 09:56 AM   #18
ka mano
Member#: 78022
PdxT built 2.5L 6sp
30R.82, 274/276, H2O+meth
Default a relevant thread: '235 40 17 Owners'
http://forums.nasioc.com/forums/showthread.php?t=343100
twotacosfor99cents has a nice photo in post #7.
ka mano is offline   Reply With Quote
18x8.5 +35 offset w/ 235/40/18 tires on 05 WRX? fl4tsc Tire & Wheel 4 10-05-2009 02:21 AM
e35 18x8.5 w/ 235/40/18 Tires on 06 CGM STi suby_dude Tire & Wheel 10 09-16-2007 01:56 PM
Is it ok to use 215/60/16 tires on WRX? gopsu Newbies & FAQs 19 08-22-2006 12:21 AM
okay to put 235/40/17 on Rota SDRs (17x7.5) Impreza2003 Tire & Wheel 0 06-03-2005 11:13 PM
is it okay to have newer tires up front, and half warn tires in the back? Kevex Tire & Wheel 3 10-04-2003 12:09 PM
