Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 04-18-2005, 06:13 PM   #1
Exo
Member#: 75866
2005 2.5 RS
Question Sti head/block on 2.5
I have purchased almost everything I need to turbo my RS. But I have been told that I wont get close to a WRX even after this. So I started looking in to doing a swap with a Sti head and block. My problem lies in will the valve timing work? What about the ecu connections? Will a UTEC act the same? Pretty much the wiring is the main problem I think I will run into. Or have been told I will run into. Thanks for the help.
Exo is offline   Reply With Quote
Old 04-18-2005, 11:27 PM   #2
MeshmeZ
Member#: 58908
'07 STI
umm if you do the turbo system right you will be up with stock wrx's easly. reliability is another question though. if you are going to go with an sti swap you are going to need the sti ecu and harness.
MeshmeZ is offline   Reply With Quote
Setting Timing - Replacing Head Gasket on 2.5 DOHC Tessai Normally Aspirated Powertrain 8 05-20-2011 09:16 AM
2.5 litre sti heads (fully built) 2.5 crank, AVCS cam gears 700hp Engine/Power/Exhaust 7 11-24-2007 02:37 PM
STI intake manifold on 2.5 RS engine SubeSTIle Subaru Conversions 10 02-16-2007 03:15 PM
sti full catback on 2.5 rs mrruins Normally Aspirated Powertrain 15 09-09-2004 10:21 AM
JDM GD STi control arms on 2.5 RS SSLegacyGT Brakes, Steering & Suspension 10 08-07-2003 05:53 PM
