Old 07-10-2005, 12:51 PM   #26
The Deliverator
Member#: 42376
2006 92x Aero
Originally Posted by Charlie-III
OK, I may be wrong....but:
1- this statement "Exhaust gasses cool as they go through the catch can and associated tubing. As the temperature drops, water vapor condenses. This can cause a surprising amount of water to accumulate in the can. " is wrong in this thread. No exhaust gases end up in the oil catch can.
What you state is correct (and is why you see water dripping out of exhaust tips) in another context, but not here.
I agree that 'exhaust gasses' is not the correct term, but I'm still at a loss for a better term in this case. 'Nasty foul toxic filthy vapor the crankcase contains', my first idea, was a little too verbose.
I'm entirely open to suggestions for a more accurate term...
2-You don't really want to PRESSURIZE an engine block (in the oil gallery), you really only want to pull a vacuum. this reduces some of the pumping of air underneath the pistons as well as removes combustion chamber gases that get by the piston rings.
Here I just wanted to point out that it wasn't me that suggested that 'pressurizing' was a good idea, and someone else already corrected whoever it was that did write that. I've actually spent the last few days looking into a vacuum pump to use in place of the pcv. :-)
The Deliverator is offline   Reply With Quote
Old 07-10-2005, 03:17 PM   #27
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
stanh04wrx: Don't get me wrong, I like your work on this thread.
I just wanted to clear up a few things.
As to using a vacuum pump for the block, any possible gains would more than likely be negatively offset by the power required to drive the pump. So, just make sure the existing system is working correctly.
To anyone else, the PCV is a spring loaded check valve that works on vacuum. Yes, you can clean them (I use carb cleaner). To check them, remove and shake end to end. If you hear a clicking, the spring loaded valve is probably working OK.
A PCV is fairly cheap, so it may be better to just replace, but keep a clean one handy "just in case".
Charlie-III is online now   Reply With Quote
Old 07-10-2005, 04:07 PM   #28
The Deliverator
Member#: 42376
2006 92x Aero
I actually just got back in from replacing the PCV valve on my 04 wrx. Sounded a little gummed up compared to the new one, but definitely still working. Seemed kind of pointless because of my planning to replace it with a pump, but the pump is at least a month away.
I got the idea for a vacuum pump from a recent thread in the 2.5l forum here. Did a lot more research and it seems legit. Doesn't seem to violate any of those pesky conservation of energy laws, either. :-) Can't hurt to try, so I'm going to try to snag an electric vacuum pump from a local u-pull-it.
Oh, on the subject of pcv's... North Ursalia helped me out when I was looking for this, so I'm going to post the info here to help people who do a search to find it- 2004 wrx pcv valve part number is 11810AA040. Around $15, and it's just the valve. For abour $7, you can get the valve *plus* the plastic fitting that it lives in. Much easier to swap out, and it costs less.
Old 07-10-2005, 06:22 PM   #29
The Deliverator
Member#: 42376
2006 92x Aero
I've edited the faq so that 'exhaust gasses' has been replaced with 'blowby products' for the sake of accuracy. Thanks to Charlie-III for pointing out the potentially misleading wording.
Old 07-17-2005, 11:31 AM   #30
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
couple of CC install links from our site:
http://www.scoobymods.com/forums/showthread.php?t=2769
http://www.scoobymods.com/forums/showthread.php?t=3346
feel free to move them in to the FAQ, nice job BTW
Peaty
www.ScoobyMods.com
Peaty is offline   Reply With Quote
Old 08-03-2005, 05:07 PM   #31
drewdogg
Member#: 90003
2005 STi
I dont know how else to say this without sounding like im telling you but...
i thought PCV was to vent crank case exhaust gases. There is a small amount of exhaust blow-by past the piston rings which is what's being vented in PCV system. This is passed back to the intake to be reburned reducing emissions. In the ooold cars they just has a hose (kinda like a peet trap *spelling* for a sink or toilet) bent like a 'J' that came right from the crank case that would vent the gases into the blow by air from driving.
drewdogg is offline   Reply With Quote
Old 08-03-2005, 07:20 PM   #32
The Deliverator
Member#: 42376
2006 92x Aero
Not sure what you're referring to. Does the FAQ somewhere define the PCV line as doing anything besides venting crankcase gasses? It definitely shouldn't. If you've found that it does, let me know where and I'll fix it.
Old 08-04-2005, 09:51 AM   #33
drewdogg
Member#: 90003
2005 STi
He is right, where there is exhaust blow by past the rings, which would mean there is exhaust gases in the catch can, thats what the PCV system is for.
And just a bit of something i actually learned at school --- the water dripping out of the muffler is from the catalytic converter, where it uses a metal screen (which is a catalyst-duh) that converts and combines exhaust gases into more 'earth-friendly' gases; oxidizes hydrocarbons (unburnt fuel) to carbon dioxide and water, reduces nitrogen oxides to nitrogen and oxygen, and oxidizes carbon monoxide to carbon dioxide.
Old 08-17-2005, 03:59 PM   #34
Rick Schu
Member#: 34661
I've been heavily researching catch cans and have come up with the following:
1. Money no object, the most effective catch can is the Racor CCV4500. It is actually designed specifically to remove oil from a PCV system, has a replaceable filter, has a bypass if the filter becomes clogged, and drains out of the bottom (supposed to go back to your oil pan, but you can add a petcock if you want). These are used on turbo-diesel trucks and marine engines. This model is effective up to 350 HP. I've found it online from about $215 to $250. More info at: Racor crankcase ventilation filter
2. Second best, as mentioned before, is the Accurate Machine Works AMW001. It is billet alluminum cylinder that uses a stainless steel mesh "filter" that helps to condense the oil and a series of "undercut" on the cylinder wall keep the oil from climbing back up. Very high quality piece. Problem is, on August 1st they increased the price from $80 to $160. I emailed them and they said it was due to a production cost increase.
3. Next up you have the usual catch cans - Greddy, Helix, Perrin for between $75-$100. People complain that the cylinder is just empty, but they actually do work, to an extent. What happens is, the air goes into the cylinder and swirls around the walls where the oil vapor condenses and because oil is heavier than air, falls to the bottom of the tank. People add wool and such to these, but I'd worry about something breaking off and getting in my turbo. I would imagine that the round cylinder designs would be better at collecting the oil, but I don't quite know the physics behind it.
4. DIY - A lot of people are using the air compressor filters available at home improvement stores. Parts for this conversion are around $20-30 or so. They are usually much smaller than the catch cans in #3. Seems like the best results come from removing the filter. Again, the air swirls around in the container and collects. Problems with this set up is 1. They are not designed to take extreme heat (such as close to the turbo), so mounting options are limited. 2. There are precautions about using the filter with synthetic oil vapors as this may cause the container to shatter (why, I'm not sure).
5. DIY - $3 - cheapest alternative is attaching the Fram G3 fuel filter. This is a generic fuel filter with a clear container. When it becomes saturated with oil, just buy a new one and replace. Typically lasts people between 1-2 oil changes. Problems are some arguments about the 2-way flow may be affected as the filter will have more restriction one direction than the other. The consensus is that the filter should be set up to flow in the direction of the intake. Also, if you don't watch the filter and it becomes too saturated, it might create a big problem.
Rick Schu is offline   Reply With Quote
Old 08-17-2005, 04:10 PM   #35
Rick Schu
Member#: 34661
Also, Crucial Racing has a catch can in development. I'm curious what they will come up with as usually their stuff is high quality. They say the development is going slow, though.
Old 08-24-2005, 04:23 PM   #36
tm999xxx
Member#: 34408
07 Spec B
SoapBox?
^^New mini Catch can...In developement as we speak should be ready by next week
tm999xxx is offline   Reply With Quote
Old 08-31-2005, 10:24 AM   #37
Snoop
Member#: 20626
2002 WRX Wagon
Where does one get foam lawn mower filters? I have two catch cans installed, but they're not collecting anything substantial. I've had them on for a couple weeks now.
I went on the cheap and did the air compressor filter route. I've tried with and without that hard white thing screwed into the cap. With the white thing in, it becomes darker in color, but nothing is collecting in the bottom. I'm guessing my air flow is too smooth through the cans?
Does anyone have the air compressor filter versions and is catching anything substantial without filtering media?
Snoop is offline   Reply With Quote
Old 09-05-2005, 03:31 AM   #38
vipernj
Member#: 86854
2004 fx35 02 Z06
Beryllium, Millenium Yell
Why is is bad to "T" off the PCV and crank lines into the can, cap off the inlet and then run the line out of the can to the lines of the front of the intercooler? This is how I installed mine, but in the FAQ it says not to do this because it throws boost in places it shouldnt be.. I following the directions on www.scoobymods.com for "Greddy Catch Can Install." Should I change it over?
vipernj is offline   Reply With Quote
Old 09-05-2005, 10:10 AM   #39
The Deliverator
Member#: 42376
2006 92x Aero
The crankcase should always be under vacuum. Off boost, this vacuum comes from the intake manifold and inlet hos. On boost, the PCV valve closes, blocking off the connection to the intake manifold and all the vacuum comes from the air inlet. The reason this happens is because, on boost, the intake manifold has positive pressure rather than vacuum.
Unless I'm mistaken, the valve covers *can* see boost. If you T the valve covers into the crankcase vent line, you're going to be stuffing more foul air into the crankcase instead of sucking out what's already there.
Maybe if you kept the PCV valve attached to both the crank vent and the intake manifold and T'd the valve cover vents in between the PCV and the turbo inlet you'd be ok. Then again, maybe not.
Old 09-10-2005, 07:43 PM   #40
HighPlainsDrifter
Member#: 91979
2004 STI
This is how I did my oil catch can on the Valve-cover side.
I hope this is a correct demo. I wrote it like a how-to, but I'm posting it here to let people tell me if its done right.
Supplies from Home Depot
Clamps
Connectors
Oil Catch
Walk-through
Step 1
Step 2
Step 3
Step 4
Step 5
I haven't yet tried to do the crankcase side.
HighPlainsDrifter is offline   Reply With Quote
Old 09-19-2005, 11:20 PM   #41
max_psi
Member#: 96373
Default Greddy catch can in GC8
Hey Guys,
Hoping you can help me I don't know if this is the right place to post. I'm am going to hook up a Greddy catch can with two inputs, on the crank case only. I was going to connect one end of the catch can with a t piece between the crack case vent tube and PCV tube, and the other end of the catch can to the intake manifold. The problem is where in the engine bay of my GC8 are these located. Can anyone see a problem with my installing it this way? Has anyone got any pictures of the GC8 with a catch can installed?
max_psi is offline   Reply With Quote
Old 10-02-2005, 08:02 PM   #42
spoolinsuby
Member#: 80182
Look ing for a GG
Wagon
Originally Posted by stanh04wrx[I
Wrong way:[/i]
Disconnect the PCV<->Inlet line as well as the Crank Vent<->Inlet line. "T" the PCV and Crank vent lines together, and run the remaining end of the "T" to a single nipple on the inlet pipe. Cap the remaining nipple on the inlet. You'll be sending boost into places that definitely shouldn't ever see any. Bad idea.
How does boost get in the system?
spoolinsuby is offline   Reply With Quote
Old 10-23-2005, 12:51 AM   #43
gpatmac
Member#: 18446
2002 WRX wagon
psm
Last edited by gpatmac; 10-23-2005 at 03:46 AM. Reason: still getting my thoughts together
gpatmac is offline   Reply With Quote
Old 10-23-2005, 01:19 AM   #44
gpatmac
Member#: 18446
2002 WRX wagon
psm
Old 01-08-2006, 11:30 AM   #45
TexRex2002
Member#: 36303
06 Evo IX
That is definitely a super clean installation. If I were going to pay $200 for a pair of catch cans I'd buy those for sure.
200? pff... try 320 for just the cans!!!
TexRex2002 is offline   Reply With Quote
Old 02-06-2006, 09:02 PM   #46
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
FYI stanh04wrx and all:
I just thought you should know, the link to the exmple at the top of this thread that points to the ImprezaWRXSTi forum has changed to:
http://www.iwsti.com/forums/showthread.php?t=17214
chrisarella is offline   Reply With Quote
Old 02-06-2006, 10:47 PM   #47
The Deliverator
Member#: 42376
2006 92x Aero
thanks for the heads up; the faq's been fixed
Old 02-06-2006, 11:11 PM   #48
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
^^^no problem, and thanks for the FAQ
Old 03-11-2006, 04:57 PM   #49
NeedAWD
Member#: 30831
2004 WRX
Java Black Pearl
Clamps
Connectors
Oil Catch
Walk-through
Step 1
Step 2
Step 3
Step 4
Step 5
nice and simple. I'm afraid to cut that pipe tho.
NeedAWD is offline   Reply With Quote
Old 03-13-2006, 01:43 AM   #50
dougkmcse
Member#: 85938
2004 WRX
How fast does the filter fill up. I bought one of the cheap ones from ebay. I then modified the can so i could install a piece of lawnmower air filter in it. then i installed it in front of the battery. oh this is in a 04 wrx. I tested and ther were no leaks. It seems to be working good. I have this installed on the valve cover vents. It is amazing what it catches. I don't know if it is the way i installed it by the battery, I get alot of water in it after along drive?
dougkmcse is offline   Reply With Quote
Catch can maybe reduce oil use? leighton1245 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 06-05-2010 07:38 PM
Oil catch can...or catch canS?? BoXinWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-28-2009 06:01 PM
Installed OBX catch can... (another catch can thread) txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-10-2008 02:00 AM
WTT(HR): Greddy Oil Catch Can with Perrin Oil Catch Can scooby_wooby MAIC Private Classifieds 1 03-24-2008 10:01 PM
WTT: Cusco catch can for a perrin catch can sti charles Engine/Power/Exhaust 10 11-29-2007 02:04 AM
