Old 04-18-2005, 09:28 PM   #1
uncle lewie wrx
Member#: 78066
Default Quick Question, AP and Cat Back
Well about 2 weeks ago i installed the AP, flashed the base map and real time map (stage 2). I have an up and down pipe (background info). An this weekend im putting on a bosal singe tip exhaust. They sent me the two tools to reset the ECM. My question is do I need to re-flash my car because i re-set the ECM, due to installing the exhaust????
Any info would be helpful, thanks!
Uncle Lewie
uncle lewie wrx is offline   Reply With Quote
Old 04-18-2005, 09:45 PM   #2
WRX_2NR
Member#: 66763
04 WRX
Uncle Lewie
What tools do you speak of?
If its just doing an ECU reset it won't hurt anything. Probably help the ECU relearn with the new catback
No need to do another reflash, the base map is already loaded.
WRX_2NR is offline   Reply With Quote
Old 04-18-2005, 09:45 PM   #3
WRC-Go
Member#: 29917
2003 WRXWgn-WRB sold
EVO IX-MR, 98 Viper
Nope, Stage 2 includes the exhaust mods - resetting the ECU is good, though.
But you do NOT need to run a real time map over your base map.
WRC-Go is offline   Reply With Quote
Old 04-18-2005, 09:48 PM   #4
uncle lewie wrx
Member#: 78066
The"tools" i got witht exhaust inside the box. The paper about them reads "if the engine has over 500 miles or more, the engine control module (ECM) memory must be cleared before starting vehicle. To clear ECM read suby service manual."
Uncle Lewie
Old 04-18-2005, 10:51 PM   #5
uncle lewie wrx
Member#: 78066
Any1 else got any advice??
Uncle Lewie
Old 04-19-2005, 10:02 AM   #6
WRC-Go
Member#: 29917
EVO IX-MR, 98 Viper
Clarification: to clear the ECU, unhook negative battery cable and pump brakes for a few seconds. This will remove the "learning" your stage two ECU has overlaid and give it a fresh start with your somewhat less restrictive axleback exhaust. It will not erase your Stage 2 programming, so no need to re-install that. You car will "learn" the new exhaust system now.
nee help quickly please on SPT cat back exhaust and Cobb stage 2 last lemming alive Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 01-14-2010 02:09 PM
quick question about NA cat and FI cat bnr34rb26dett Newbies & FAQs 1 01-23-2009 11:12 AM
up-pipe and down-pipe with stock 3rd cat and cat-back=LOUD? VajraTLR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 01-12-2004 08:51 AM
up pipe, down pipe, and cat back question 04subaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-22-2003 08:53 PM
Downpipe and Cat-back question Johnny5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-04-2003 11:23 PM
