Old 04-18-2005, 10:37 PM   #1
drdome99
Member#: 56571
'05 LGT - Stage 2
Default 5th gear issues with UTEC...
Ok so I got UTEC tuned up at turboXS and everything has been fine and dandy, running like a beast. I took it up to the track and on my last couple runs I noticed that as I am shifting into 5th I am getting the cruise light flashing (detecting knock if I'm not mistaken). I was done running for the day so I left and was doing some 5th gear pulls from low rpm through the gear and wasn't noticing it again. Then I did a 4-5 pull and it was flashing again right as I shift to 5th. Flashes 1-3 times then stops. I also noticed another time I did a 5th gear pull I peaked exhaust temp at 900 deg. celcius. All other gears I peak maybe 800/825 and cruise around 750.
So my question is what is the deal with the 5th gear issues? Is that temp acceptable with tbe and utec?
drdome99 is offline   Reply With Quote
Old 04-18-2005, 11:34 PM   #2
StiDreams
Member#: 26315
07 Outback
Silver/Silver
I would thing 900 c is on the high side. I take it you mean the CEL (yellow) is flasning and not the cruise (green). The CEL is knock. Do you feel timing being pulled when this happens?
StiDreams is online now   Reply With Quote
Old 04-19-2005, 01:45 AM   #3
AaronWRX
Member#: 7194
2011 997.2 Turbo
POST A LOG!@#
AaronWRX is offline   Reply With Quote
Old 04-19-2005, 02:39 AM   #4
gills
Member#: 11316
1988 E30S52 DD
S14VQ35 & S13KA racecarzz
what are your AFRs?
This knock you're experiencing is probably shift knock. This happens after a shift when the ECU takes control over timing and it's at ridiculous levels causing knock. You have to enter timing values and/or add a little fuel(not sure if the fuel part is necessary) on the 0% column at the higher rev range(where the rpms drop when driving hard. I set mine from 5250 and up) so the UTEC controls it and keeps it at bay. I believe most people enter 17-20 degrees. I put 19 degrees and haven't experienced shift knock since.
gills is offline   Reply With Quote
Old 04-19-2005, 07:36 AM   #5
drdome99
Member#: 56571
'05 LGT - Stage 2
Originally Posted by AaronWRX
POST A LOG!@#
If I wasn't working on a job site 3 hours from my house for the week without a laptop I would.
5th gear issue Subpar04 Newbies & FAQs 6 02-17-2010 08:53 PM
Issues with UTEC Valet Setting - too rich? wrspssshhhh Engine Management & Tuning 19 07-18-2005 04:37 PM
CEL Issue with UTEC Inprogress Engine Management & Tuning 7 05-27-2005 06:49 PM
Wonderful 5th gear issues 340Duster South East Region Forum 9 03-01-2005 12:57 PM
will rs 5th gear work with quaif gear set? drift king Transmission (AT/MT) & Driveline 0 12-03-2004 02:01 AM
