Old 04-18-2005, 11:31 PM   #1
MeshmeZ
Member#: 58908
'07 STI
Default flywheel/clutch for swap
im putting a ej20 into my RS and keeping the RS tranny. i know i will need a RS clutch, but can i use a rs flywheel? or do i use a wrx flywheel? also what clutch/flywheel would you guys recommend? obviously im going to need something stronger than stock.
MeshmeZ is offline   Reply With Quote
Old 04-19-2005, 12:39 AM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
you use the RS flywheel...as far as what to use, you can use the stock flywheel, but any upgraded organic clutch be it ACT, exedy, rps, etc...should do you just fine...just check the torque it can hold and go from there
Old 04-19-2005, 03:34 AM   #3
MeshmeZ
Member#: 58908
'07 STI
ok so the rs flywheel has no problem bolting up to the ej20 motor? that was the only thing i was worried about.
Old 04-19-2005, 04:55 AM   #4
Kotir
Member#: 17300
1993 Widebody Wagon
748whp e98
RS flywheel works fine with an EJ20 motor. I had the same Exedy clutch/flywheel as I was using when I had my turbokit on my RS before the swap.
And the lower RS gearing does wonders over the USDM WRX gearing.
I ate an Exedy Organic Street clutch with my swap - granted it was well abused.
What killed it was doing drag launches with a JDM STi motor
-Tim
Kotir is offline   Reply With Quote
Old 04-19-2005, 11:38 AM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yup i too am running RS flywheel +act street
my car is still cable so lots and lots of peddle force is required
Old 05-05-2005, 08:36 AM   #6
Parsons
Member#: 65688
2001 junkyard heap
Black/dirt
I was going to ask this same clutch question.
Now that I have my answer, do you know the cheapest place to buy said clutches? I am seeing 400 dollar range for the act clutch...normal?
Parsons is offline   Reply With Quote
Old 05-05-2005, 09:50 AM   #7
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
yeah about 400 or more for ACT.. or you can go with the Exedy Stage 1 kit for about 330.. The ACT has more clamping force (45-50% over stock) and the Exedy has about 27% more than stock..
I'm using the Exedy on mine, peddle is not heavy at all. I went for the Exedy over ACT purely on clamping force numbers.. I don't want the tranny to get shocked any harder than it needs to, plus it should handle what i plan on doing to it.
subbyspeed is offline   Reply With Quote
Old 05-08-2005, 02:33 AM   #8
simbey1982
Member#: 72074
1997 Impreza L Sedan
Sport Red
Default diffrent
Just remember that the RS and WRX tranny's have diffrent styles of clutch fork action.....pull vs push....
if you are going to use your RS tranny you will need to buy drivetrain parts to match your RS because the WRX ones will not work....
hope it helps
simbey1982 is offline   Reply With Quote
6spd swap - flywheel / clutch dust shield mod? Bad Noodle Transmission (AT/MT) & Driveline 7 02-10-2009 09:40 PM
CO: FS: WRX Clutch/Flywheel, JDM Clutch/leftover swap parts 02rusWRX Drivetrain 33 03-09-2007 01:15 PM
Swapping STi flywheel, clutch, and PP into 5sp WRX tranny CoolRex Transmission (AT/MT) & Driveline 1 02-21-2006 12:19 PM
what flywheel/clutch for 93 JDM WRX tranny supermoose Transmission (AT/MT) & Driveline 0 08-16-2003 01:50 AM
what flywheel/clutch for 93 JDM WRX tranny supermoose Subaru Conversions 3 08-15-2003 02:34 PM
