Old 07-26-2001, 10:50 AM   #1
ITR&RSGUY
Member#: 8455
2006 WRX CTSV Viper
Silver Black Red
Default Turbo w/ no intercooler?
Aftermarket Turbo for my RS without an intercooler a bad idea? I ghave seen same stage one kits that don't run intercoolers for the turbo, is this something to stay away from? I am not looking to boost the car to 1 bar or anything, just 5psi will sufice, If I am going with low boost will a non-intercooled setup work. Thanks
ITR&RSGUY is offline   Reply With Quote
Old 07-26-2001, 10:53 AM   #2
efoo
Member#: 80
Running 5psi with enough fuel will work fine with no intercooler, from what I've seen. The operative phrase being "with enough fuel".
Edwin
efoo is offline   Reply With Quote
Old 07-26-2001, 10:53 AM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
you can run a kit w/no intercooler...
the Minnam stage I has no IC and can still maintain a serious punch... as far as long term + and - effects?
Well i dont know anyone who's been running one long enough...
As long as you dont get boost hungry you should be ok.. for quite some time to come.
j.
www.subiegal.com
Old 07-26-2001, 11:10 AM   #4
RyanC
Member#: 2634
1988 5000 CS Quattro
Tornado Red
I ran for about 2 months at 5-6psi with no intercooler. The car was pretty quick, but after putting on the IC I saw a drop in intake temps of 40 degrees celsius and there was more power at the same boost levels. I'm not even running the most efficient IC, but it was inexpensive and effective. The key is fueling and to be careful; if it starts to ping back off and you should be ok. However I'd recommend a BOV or diverter valve to help the longevity of the turbo.
RyanC is offline   Reply With Quote
Old 07-26-2001, 11:12 AM   #5
ITR&RSGUY
Member#: 8455
2006 WRX CTSV Viper
Silver Black Red
Ok whats the best Turbo kit for under 3K? I know I know a broad question, I would love and intercooler and BOV but can it be done under 3K? I just bought a House in San Fran and want to conserve a little cash :-)
Old 07-26-2001, 11:28 AM   #6
efoo
Member#: 80
save your money for the house. seriously. I've just bought one too and now wish I hadn't spent so much money on the car.
-Edwin
Old 07-26-2001, 11:32 AM   #7
Pipercub
Member#: 2188
2004 Impreza STI
82 BRAT with 12 in. lift
Given that you can obtain a Subaru Air to Water IC for about $100. and another $70 for an oil cooler core, water pump, switch and ods and ends it makes no sense not to run an IC, you are not obligated to buy the $600 Spearco one the vendor is selling.
Pipercub is offline   Reply With Quote
Old 07-26-2001, 11:36 AM   #8
SubaFastR
Member#: 5786
I don't care where you get the kit, it will end up costing you way more than $3000. If you want to go fast cheaply, get a nitrous system. If you can afford it, the Venom kit is the safest and nicest. If you can't afford the $1300 price tag, then the Zex would be my second choice at $500.
My car is easily in the 13's with the Venom kit.
SubaFastR is offline   Reply With Quote
Old 07-26-2001, 11:36 AM   #9
ITR&RSGUY
Member#: 8455
2006 WRX CTSV Viper
Silver Black Red
good pint, so like a used intercooler of a UK impreza turbo, or will one off a legacy turbo work?
Dave..........very green right now when it comes to scoobys
Old 07-26-2001, 11:40 AM   #10
Wannabeturbo
Member#: 2328
Thumbs up
Build it yourself, I made mine all at just a little over 2g. That is with an Rallispec intercooler. I bought my turbo off a '89 Ford Thundercoupe and rebuilt it for less than $300. I sent it to get balanced for about $60 and it's as good as new. What more could you ask for! The only thing that will cost you cash is the I/C and turbo piping. I can build the turbo piping for $700 that is $100 less than ASR and alot cheaper. I could only find one place that would build up and downs seperate from a kit and that was ASR. That is why I am offering them to everyone else. I can build them with less bends and look awesome too! Email me if you have any other question at [email protected]
Good luck!
-Matt Weber
Wannabeturbo is offline   Reply With Quote
Old 07-26-2001, 12:51 PM   #11
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
I agree, Make your own. Mine only cost me about $1100, but I spent the money in the wrong places. I have no intercooler and it's fine up until 7 pounds. Check out my sit and email me if you have questions.
Chad
93 1.8T
http://www.uniquemotorsports.com/subachad
subachad is offline   Reply With Quote
Old 07-26-2001, 01:00 PM   #12
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Default EJ22T motors...........
Turbo Legacys came without an IC. A friend runs one with 11psi no problem. Mine can run about 10psi no problem on the 1.8L ECU.
Scoobyslack1 is offline   Reply With Quote
Old 07-26-2001, 01:52 PM   #13
mcgyver
Member#: 1655
MY98 RS w/WRX Conv
I-Speed Tech
subachad,
I remember you from Vegas last year @ SEMA. I rode in your car, was supposed to meet up later that night at some clubs. But unfortunately, our Hotel was way the F-out there, so I couldn't make it. No more Vegas, huh? Where in Cali?
Now for Turbo content:
I just installed the LudeSpeed Kit on a friend's car last weekend, he doesn't have the IC yet. It runs fine for now @ 5psi, but he said it does get pretty Hot when sitting in traffic and under hard driving.
I have the JCS GB Kit w/VF-23, so I have about $2,800 into the kit itself. Now they cost about $3,800 I believe. Then I'm using Nissan injector's ($240), Weapon-R FPR ($95) Apex-i AVC-R ($410).
But I have all this because I run 8psi everday, then higher at the track. The car ran good without all the other goodies @ 5psi.
And I have to mention: I ran 13.3 @ 103.5 last night.
-Adam
mcgyver is offline   Reply With Quote
No turbo heatshield, no care? MF-DIF Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 101 12-03-2010 11:22 AM
Can I run no intercooler? Just temporary! Crazykev Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-01-2005 12:31 AM
02 WRX WRB hood, trunk, intercooler, turbo, various exhaust, intercooler sprayer Phatron Private 'For Sale' Classifieds 46 09-15-2005 11:34 PM
no intercooler a no-no? eclone Newbies & FAQs 7 12-07-2004 07:18 PM
