Old 04-19-2005, 01:25 AM   #1
Wrekaro
Member#: 80972
2002 Impreza WRX
Default Will 17x9 ET48 fit on all 4 corners??
I tried the wheel forum but something tells me this crowd will know better. Im very new to the subaru scene so Im still learning what will fit. I can get the wheels in any offset I want so if 48 is to low I can do 53 or whatever is recomended. Thanks for your insight.
Wrekaro is offline   Reply With Quote
Old 04-19-2005, 01:41 AM   #2
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
i think 48 would be optimal. should be the highest with lower offsets being doable, but should work with fender rolling
petawabit is offline   Reply With Quote
Old 04-19-2005, 01:43 AM   #3
STI meister
Member#: 57002
2005 STi
CGM
I think it would work, but i also think this is in the wrong forum.
STI meister is offline   Reply With Quote
Old 04-19-2005, 01:45 AM   #4
Wrekaro
Member#: 80972
2002 Impreza WRX
Yea Im sorry my thread just hasnt gotten any response over there and these wheels take forever and a month to get.
Thanks for the insight. this should look amazing!
Old 04-19-2005, 02:50 AM   #5
ChrisL2
Member#: 1444
It would help to know what your sticking this on. I've seen 9" wide wheels only on 05 STi so far without having to modify the fenders.
ChrisL2 is offline   Reply With Quote
Old 04-19-2005, 02:55 AM   #6
extraducksauce
Member#: 18555
SWRT BLUE (what else?)
Good Lord do you want to understeer or WHAT?? Why in the hell would want to run 255 tires?
extraducksauce is offline   Reply With Quote
Old 04-19-2005, 03:12 AM   #7
veightkiller
Member#: 78967
2011 335i
i put 9" wide konig moonson on my 02 wrx wagon..no problem at all...
veightkiller is offline   Reply With Quote
Old 04-19-2005, 09:41 AM   #8
drivrswntd
Member#: 55818
2003 Ram 2500 CTD
Grey
i'm running 17x9s up front with 255 toyo ra-1s all around. Car handles amazing. No understeering what so ever. I dont know why you think the car would understeer just by putting huge tires on it.
drivrswntd is offline   Reply With Quote
Old 04-19-2005, 11:20 AM   #9
Wrekaro
Member#: 80972
2002 Impreza WRX
I wouldnt run 255's anyway.
This is going on an 02 WRX sedan.
Old 04-19-2005, 11:42 AM   #10
Kontradictions
Member#: 56946
2004 Subaru WRX
Two Tone Grey
18x9 +41 with a 255/35/18 Toyo T1-S Tire...
Kontradictions is offline   Reply With Quote
Old 04-19-2005, 01:29 PM   #11
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
wow, one of the hottest, most aggressive wheel/tire set up on a Impreza I have seen so far, good job! Look very nice!
Go 265 next time, that is what I am getting next, I just confirmed it would fit
JDM addict is offline   Reply With Quote
Old 04-19-2005, 01:30 PM   #12
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
increasing or decreasing tire size on all 4 wheels together do not change the balance of the car
Old 04-19-2005, 01:52 PM   #13
ommmjido
Member#: 35746
08 White GRB
Wrong Fitment Crew #001
i've always thought that when u go with wider wheels u need a lower offset in order to clear the struts. so i'd think u'll need a lower offset than 48, maybe around 40+ since the 8" wide Volks have a 44+ offset. if u rub with the fenders thats easy fix just roll or even cut ur fenders, but if u rub with ur struts u cant just shave off part of ur struts right? but again the 17x8.5 volks have a 50+ offset and they fit fine on the STi, so dont quote me on this......
ommmjido is offline   Reply With Quote
Old 04-19-2005, 01:57 PM   #14
Wrekaro
Member#: 80972
2002 Impreza WRX
Any fender mods? If so what and do you still rub after??
Old 04-19-2005, 02:15 PM   #15
Kontradictions
Member#: 56946
2004 Subaru WRX
Two Tone Grey
front fenders are untouched, the rear fenders were cut by my body shop before the car was painted. They just took down the lip on the inner fender, doesnt rub at all...
Old 04-19-2005, 02:15 PM   #16
whiteGDB
Member#: 41081
2009 Forester
Sorry, had to quote you cause your right. I'm running TE37s 17x8.5 +50 offset with S0-3s 245/40, and I only have about ~2 mm of clearence from the rear strut. As for the rear fenders, I had to remove the rubber strip because they mere rubbing a bit.
I was thinking off going to 17x9 as well, and have already done all the calculations. The absolut highest offset you can go with is +44 maybe +45 on the stock strut, and even then you'll have to roll the rear fenders if you plan on lowering the car.
p.s. I'm riding on pink struts and springs, so I don't know how the struts compare to each other size wise. I'd say go with 17x9 +44
whiteGDB is offline   Reply With Quote
Old 04-19-2005, 02:45 PM   #17
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
whiteGDB,
I REALLY would like to see a pic of your car, white STi with 17x8.5 +50 offset Are the TE37 white? If you have a pic, please post it, I would really appreciate it
Old 04-19-2005, 02:48 PM   #18
drivrswntd
Member#: 55818
2003 Ram 2500 CTD
Grey
My 17x9's up front are et53. They have about 5mm clearance on the coilovers. Just enough to prevent rubbing.
Old 04-19-2005, 02:52 PM   #19
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
I agree 17x9 +44 would fit. I just put some 18x8.5 +45 on my 04' STi, like a few have said, the rear strut clearance is the concern, for my wheel, there is about 1/4" (~6mm) of clearance between the wheel and the strut on the rear. I say go with +44 or lower would be safe, a +43 would be safer......
Keep in mind, your camber setting have a direct effect on your wheel/tire clearance with these very aggressive width set up.....
Old 04-19-2005, 02:57 PM   #20
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
The front is wide open, the rear is the concern. Basically whatever fit on the rear would fit on the front..
Old 04-19-2005, 03:31 PM   #21
Braz
Member#: 64273
2005 STi
CGM
since we're thinking wide, i dont think most of you have seen this STi.
I think they're 305s, or something.
Braz is offline   Reply With Quote
Old 04-19-2005, 03:58 PM   #22
Kontradictions
Member#: 56946
2004 Subaru WRX
Two Tone Grey
you have any more shots of this car?
Old 04-19-2005, 04:13 PM   #23
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
I believe they are 275's not 305's. Not sure about the rim size....18x?? CCW Wheels. I think trhoppe on here would know....mainly hangs out in the motorsports forum.
SloRice is offline   Reply With Quote
Old 04-19-2005, 04:20 PM   #24
drivrswntd
Member#: 55818
2003 Ram 2500 CTD
Grey
Well my rears are 17x8.5 et 48 with the 255, i dunno if that helps at all.
Old 04-19-2005, 04:33 PM   #25
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
tires that stick outside of the fender with 1000 lbs springs suspension that don't travel at all don't count in my book. With those kind of set up, the width is limitless, the car just can't turn a whole lot
FS:NY OEM Impreza WAGON suspension and hubs--All 4 corners singincanary Suspension/Brakes/Handling 10 03-12-2008 11:57 AM
stock STI exhaust; will it fit on ALL wrxs? oilybirdy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 01-02-2006 09:47 PM
Will 17x9 ET48 fit on all 4 corners?? Wrekaro Tire & Wheel 7 04-20-2005 04:42 PM
Pictures! sti v6 suspension for GC8: all 4 corners complete supermoose Private 'For Sale' Classifieds 1 11-18-2004 05:53 PM
Will a 17x9 wheels fit on the WRX? Patrick [Buffalo] Brakes, Steering & Suspension 5 10-29-2001 08:59 AM
