Old 04-19-2005, 01:53 AM   #1
happyparrot
Member#: 61896
1998 2.5rs S/C
RBP
Unhappy I think I blew a piston ring or cracked my head, what do you think?
The car drives normally and sounds normal, but today after I took her out for a spin the oil light was flickering. So I turned her off and checked the oil levels and there was plenty of oil. But as I was removing the dip-stick it sucked in a huge amount of air. So I started up the car and removed the oil cap, there was air puffing in and out of the oil fill tube. I smelled the air and it had a hint of fuel. So here's what I'm thinking it can be:
- I cracked the head and the compressed air is pushed into the oil lines.
- I blew a oil seal O-ring on the piston with same result
- Bad PCV (somehow forcing air inside the crank case???)
Here's the strange thing, you would think that with one cylinder loosing so much compression the engine would misfire, but it hasn't and it's running as smooth as new. I'll do a compression check on Saturday to see what's going on the inside.
I would like your input as far as what you think it is? Anyone else experience this? If someone wouldn't mind doing me a favor, go out to your car start it up, remove the oil cap and see if it sucks air in and spurts it out, maybe it's supposed to do it .
Thanks for your responses
-Daniel
happyparrot is offline   Reply With Quote
Old 04-19-2005, 11:52 AM   #2
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Nope, no pressure fluctuations with the oil cap open.
powerlabs is offline   Reply With Quote
Old 04-19-2005, 02:21 PM   #3
happyparrot
Member#: 61896
1998 2.5rs S/C
RBP
Thanks for checking it out, now there is no doubt I have a problem
Old 04-19-2005, 05:29 PM   #4
sidewayz
Member#: 5810
2001 S366 2.5RS
it is normal for any car to make "puffing" noises with the oil cap off. its called valve over lap. dont sweat it.
You could have a bad oil pressure sender. its located right behind the alt.
sidewayz is offline   Reply With Quote
Old 04-19-2005, 05:56 PM   #5
happyparrot
Member#: 61896
1998 2.5rs S/C
RBP
I also thought of this, but I'm pretty sure I've removed the oil cap before and it didn't do the air puffing thing before.
I checked the compression today, here are my results:
cyl 1: 175psi
cyl 2: 176psi
cyl 3: 175psi
cyl 4: 178psi
Old 04-19-2005, 05:59 PM   #6
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Sounds like you have nothing to worry about. It could easily just be the oil pressure sender. What weight oil are you running?
OneOBS is offline   Reply With Quote
Old 04-19-2005, 06:45 PM   #7
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Remove oil pressure sender and install a mechanical oil guage in there and see what your oil pressure is. It's 1/8" npt. Get a guage that goes to at least 80 psi. Once you determine that your oil pressure is good then you can condemn the pressure sender.
Tim Sanderson is offline   Reply With Quote
Old 04-19-2005, 07:24 PM   #8
happyparrot
Member#: 61896
1998 2.5rs S/C
RBP
Thanks a lot for the input guys, I'll go install a mechanical oil pressure gauge on the car with in the next 4 hours (after I finish home work) I'll let you know what my oil pressure readings are.
Ones again thanks for the input it is really appreciated.
Old 04-19-2005, 11:07 PM   #9
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
check your PM's (about that bumper!)
twizzstyle is offline   Reply With Quote
Old 04-20-2005, 12:41 AM   #10
happyparrot
Member#: 61896
1998 2.5rs S/C
RBP
I did, I'm waiting on an answer from my brother, I'll let you know as soon as I hear something.
I checked the oil pressure, and its
about 85-90psi at idle.
My plans for upgrading my suspension, what do you think/Question shamrock 05 Brakes, Steering & Suspension 28 05-15-2009 10:55 PM
Thinking of changing my Rims.. what do you think? brcewane Interior & Exterior Modification 7 03-06-2005 08:54 PM
Upgrading my old Omori gauges for my STi, what do you think? Corn-Picker Interior & Exterior Modification 21 12-29-2004 03:23 PM
Keep my '01 RS, or get a WRX? What do you think? IMPRZME General Community 25 05-18-2002 07:10 PM
18's on my Subie, what do you think??? Rimmie General Forum Archive 32 06-24-2000 03:07 PM
