04-19-2005, 03:42 AM | #1 |
Member#: 85418
Vehicle:1999 OBS |
Window not rolling down.
Hi,
my passenger side windows doesn't roll down and the motor not even trying. however, it rolls up fine (because the window works occationally). I checked the passenger side switch and it's not causing the problem. what could be wrong? thanks for the inputs.
04-19-2005, 07:40 PM | #2 |
Member#: 63445
Vehicle:2002 WRX Wagon PSM |
I'm not quite clear on the entire problem. I am assuming you have four power windows (OBS). How many are causing a problem?
Does your OBS have a window lock-out switch on the driver's side panel? Have you had your door panel off recently? Just throwing out some suggestions. Bad switch, bad ground, shorted wire. |
04-25-2005, 12:05 PM | #3 |
Member#: 36700
SCIC
Vehicle:EVO 9 07 GSXR 750 |
Wirelessly posted (treo 600: Mozilla/4.0 (compatible; MSIE 6.0; Windows 95; PalmSource; Blazer 3.0) 16;160x160)
I have the same problem. on my car I know that the switch in the door is faulty |
04-25-2005, 02:05 PM | #4 | |
Member#: 85418
Vehicle:1999 OBS |
how do you make sure the switch is faulty? and not the motor? Last edited by xtra; 04-25-2005 at 02:11 PM. |
04-25-2005, 02:11 PM | #5 | |
Member#: 85418
Vehicle:1999 OBS |
Only the front passenger windows has this problem, and it's wierd that it goes up fine. it's not the lock-out switch on the driver side, cuz I can open the rear windows from the driver door panel. I did not have my door panel off recently. any more suggestions? |
Window will roll down but not up!? | GoneSingle | Electrical & Lighting | 2 | 08-04-2010 12:50 PM |
Passasnger window not rolling down | IrishStyle | Interior & Exterior Modification | 5 | 05-08-2009 01:56 PM |
window not rolling down smooth. | sigurd | Interior & Exterior Modification | 0 | 08-21-2008 07:41 PM |
Driver side window will not roll down | Nettat | Electrical & Lighting | 0 | 06-09-2003 05:01 PM |
