Old 07-26-2001, 10:10 AM   #1
Jonathan_Yi
Member#: 2030
2000 2.5RS coupe
Blue Ridge Pearl
Question Question about Whiteline adjustable rear sway bar
I just got the bar today and it didn't come with any instructions. Which way do i put the bushings on the mount? On the flat side of the bushing, it says "L--> <hole> <--R" and the side where it says "<--R" is where the cut in the bushing is, to put on the bar.
Also, do I put the grease on the outside or inside of the bushing?
Thanks
Jonathan_Yi is offline   Reply With Quote
Old 07-26-2001, 11:11 AM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
The grease goes inbetween the bushing and the sway bar. As for the bushing orientation, I don't think it makes that much of a difference which way you put them. I can't remember which way I put mine, but I've got no problems.
Just be careful to re-check your bolts after about a tank of gas or so. I lost a bolt that connected my sway bar to my endlink -- I was *not* a happy camper.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 07-26-2001, 11:36 AM   #3
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
As far as I could tell, both bushings are the same. Just install them so that the flat part is facing up.
Make sure you use lots of grease, or you'll get a creaking sound that will drive you nuts and be hard to find. Not speaking from expirence, just what I've heard
Impreza Rider is offline   Reply With Quote
Old 07-26-2001, 12:03 PM   #4
bgsntth
Member#: 3441
05 OB XT
Blk
Good advise. Definitely recheck your bolts after a couple 100 miles, mine was this close ( ) to falling off a week after the install.
bgsntth is offline   Reply With Quote
Old 07-26-2001, 10:19 PM   #5
Jonathan_Yi
Member#: 2030
2000 2.5RS coupe
Blue Ridge Pearl
Ok, it was very easy to get the OEM sway bar off, even without taking off the muffler. When I got to putting on the last bolt, for the bushing mount, it wouldn't bolt in straight so I fiddled with it for liek an hour before my dad just decided to force it in. So if not for that bolt it would've taken me about 40 min, including time to take pics of the 2 bars together and greasing up the bushing.
Haven't gone for a drive yet, but tomorrow I will.
Old 07-27-2001, 03:53 PM   #6
Norris
Member#: 3146
00 Impreza TS
Blue Ridge Pearl
If the bolts have a tendency to get loose, should I just slather the thing with locktite before tightening it? I'll be sure to check it out after about 100 miles, but really, the factory ones stay on by themselves, so maybe the locktite would do the trick. Any thoughts?
Norris is offline   Reply With Quote
Old 07-30-2001, 09:23 AM   #7
Norris
Member#: 3146
00 Impreza TS
Blue Ridge Pearl
bump
Whiteline Adjustable Rear Sway Bar and Noltec Rear Endlinks aspenwhitewrx Suspension/Brakes/Handling 12 07-06-2008 02:06 PM
Whiteline adjustable rear sway bar questions WRX_02_227 Brakes, Steering & Suspension 1 05-27-2002 01:12 PM
Whiteline adjustable Rear Sway bar annointed Car Part Reviews 13 10-13-2001 03:19 PM
Watch Out : Whiteline adjustable rear sway bar tmat3 Brakes, Steering & Suspension 1 06-14-2001 04:49 PM
Who has the best current buy for the Whiteline adjustable rear sway bar? Robmat Brakes, Steering & Suspension 2 03-23-2001 10:09 PM
