Old 04-19-2005, 09:41 AM   #1
GotTurbo
Member#: 64186
1998 A MONSTER
SOON BMW STEEL GREY
Default compression test!!!
hey i wanted to know if any knows the stock compression of a 2.5 dohc engine in my 1998 legacy 2.5 gt. any ideas cause i was thinking of doing a compression test to see if they are all upo to par.
-matt
GotTurbo is offline   Reply With Quote
Old 04-19-2005, 11:30 AM   #2
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
Mine were all ~140 psi after I had a valve job done and replaced the HG. More important than what number they all are (generally!) is that they are all +/- 5-10% or so of each other, i.e. if one is 150, then 140-160 is not a bad range for the others to have. They should wear about the same, so if three are 130, and one's 110, you may have an issue on that cylinder.
I believe our engines have a compression ratio of 9.7:1, so that means you should see 9.7 times atmospheric pressure, which is 14.7 psi at sea level, so that would equal a compression level of ~143 psi at sea level.
-Aaron
fastenova is offline   Reply With Quote
Old 04-19-2005, 11:33 AM   #3
GotTurbo
Member#: 64186
1998 A MONSTER
SOON BMW STEEL GREY
thx alot for that help.
-matt
Old 04-19-2005, 02:00 PM   #4
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Thats strange mine were all 193 and one around 195.
MY99 2.5GT is offline   Reply With Quote
Old 04-21-2005, 06:47 AM   #5
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
I dunno how they'd be that high. SOHC EJ25s run 10.1:1 I think, which should only be around 150psi. If you were running high compression pistons, like 13:1, that would make sense... but otherwise, I don't know how your numbers could be that high...
-A
Old 04-21-2005, 08:27 AM   #6
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
NO wonder my head gaskets keep leaking. I have 13:1 compression
Old 04-21-2005, 08:27 AM   #7
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
No I don't really have 13:1 compression pistons.
Compression Test and Boost Pressure Test costs? BrigadoonB Newbies & FAQs 3 08-17-2008 10:20 PM
Recommonded Shop for Compression Test and Leak down test? stook2003 Vancouver Impreza Club Forum -- VIC 0 07-02-2007 04:20 PM
Odd compression test and leakdown test numbers SloRice Built Motor Discussion 10 11-13-2006 10:07 AM
What the compression test and leakdown tests SPEC for 05 STI hilfiger4you Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 12-25-2005 04:43 PM
Compression Test vs. Leak Down Test dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 08-17-2002 11:42 AM
