Old 04-18-2005, 03:33 PM   #1
STISTL
Member#: 69659
07 BMW 335
12.6 @ 111.1
Default ? About 05 AP
Looking at the live boost there seem to be a difference between the AP
and my boost gauge wich one is more accurate.
Thanks, Marcos
STISTL is offline   Reply With Quote
Old 04-18-2005, 03:58 PM   #2
dcwrx2
Member#: 69005
'04 4EAT Wgn
AP reads the boost by tapping what boost signal received by the ECU, via the boost sensor. So AP basically reads what exactly the ECU reads. I'll say AP is accurate as long as the ECU is accurate, otherwise the ECU is seeing inaccurate boost from the sensor so the mapping is also incorrect. Anyway, how off is your readings between AP and the boost gauge?
dcwrx2 is offline   Reply With Quote
Old 04-18-2005, 04:03 PM   #3
STISTL
Member#: 69659
07 BMW 335
12.6 @ 111.1
dcwrx2. Thanks for the quick replay dif is about 2 psi more or less at WOT ( for a moment) then it goes down to 1.-.5 more than the boost gauge. BTW I have Autometer Gauge
Thanks, Marcos
Old 04-18-2005, 04:56 PM   #4
dcwrx2
Member#: 69005
'04 4EAT Wgn
I heard from local tech that autometer isn't very good in accuracy (even though I was considering autometer at first, I eventually ordered Defi after some recommendations). I'm not saying your autometer is defective, but if you get inconsistant boost readings and sometimes it is "more" and sometimes it is "less", I think it's acceptable. Maybe it is due to the internal structure of the gauge such as coil springs, or the rubber hose connecting between the gauge and the T-connector flexes/shrinks due to sudden change in pressure. If you getting "always more" or "always less", then there is really a problem.
Use your boost gauge as an indication of abnormal boost spikes or surges, rather than keep monitoring for its accuracy, may keep you away from worrying about it. ;-) Afterall, these gauges only give you approximate value for reference. Most stock speedometers when used with stock size tires, are set to have slightly higher reading for "safety" issues too. When you read 70mph on speedometer, you maybe actually running at 65-68 mph.
Old 04-18-2005, 05:17 PM   #5
STISTL
Member#: 69659
07 BMW 335
12.6 @ 111.1
It makes perfect sense Thanks BRO....
Old 04-18-2005, 05:35 PM   #6
South Coast Subaru
Member#: 21173
2003 WRX Sedan
BLue
Definitely ap is more accurate.
Ferdie
www.southcoastperformance.com
South Coast Subaru is offline   Reply With Quote
Old 04-18-2005, 05:42 PM   #7
dcwrx2
Member#: 69005
'04 4EAT Wgn
I vote for these suggestions to Cobb:
1) In next generation AP, add an analog gauge on the AP which incorporates with the "read live boost" feature.
2) Make an AP "pod mount" or "steering column mount" so we can mount the AP and read off the boost accurately with no mess.
Old 04-18-2005, 09:15 PM   #8
WRC-Go
Member#: 29917
2003 WRXWgn-WRB sold
EVO IX-MR, 98 Viper
Is this feature (live boost) available on the AP for 02/03 WRXs? I can't find any mention whatsoever of it in the manual that accompanied my AP. 04/05 only mebbe??
WRC-Go is offline   Reply With Quote
Old 04-18-2005, 09:27 PM   #9
dcwrx2
Member#: 69005
'04 4EAT Wgn
It doesn't mention in the User Manual for 04-05 AP too, but it is the feature on the main menu, scroll to the bottom (probably under "Revert to Stock"). Not sure if 02-03 gets this feature though...
Old 04-19-2005, 01:00 PM   #10
WRC-Go
Member#: 29917
EVO IX-MR, 98 Viper
Just checked and it's there; odd there's nothing in the users manual about this feature.
Anyway, it works well.
Old 04-19-2005, 01:24 PM   #11
dcwrx2
Member#: 69005
'04 4EAT Wgn
I made a gimp "mount" for the AP so I can use it as a temporary digital boost gauge on the way I drive to work, hehe... The way I did is to pull out the cup holder between the stereo and the A/C vent (not sure if it's the same for other WRXs), then run the black DiagPort-to-AP cable thru the hole of the cup holder, place the AP above the cup holder, and connect the cable to the AP. Then, fasten the AP with some regular rubber bands with the A/C vent behind the AP, and the cup holder. It looks stupid, but as I said, it's a good for temporary solution, lol.... BTW, if you use black rubber band instead of yellowish brown like mine, it looks nicer coz the color matches, hehe.
Old 04-19-2005, 01:27 PM   #12
crazymikie
Member#: 56321
2006 Honda El Camino
Green
The one thing to consider is that the AP can only sample data from the ECU a finite number of times per second. IIRC, for one parameter, you can read it about once every 100msecs.
With a boost gauge, you will see fluctuations/spikes that get missed by the sampling rate of the AP.
Mike
crazymikie is offline   Reply With Quote
Old 04-19-2005, 02:28 PM   #13
dcwrx2
Member#: 69005
'04 4EAT Wgn
I understand, and I have the gauges sitting at home. I'm just waiting for a time that I don't need to work so that I can have time to do the installation work. =)
BTW, AP shows the boost samples at about 4 times per second.
FS: 04 ap v1 and 05 ap v1 Carbon888 Engine/Power/Exhaust 7 04-23-2008 01:27 PM
04 Ap,05 Ap?? Dizzuque Newbies & FAQs 2 11-13-2006 10:10 AM
we know the 02/03 requires brackets for an 05 front end swap, how about 05 to 02/03? bigworm Interior & Exterior Modification 5 02-21-2006 10:13 AM
Question about Cobb AP Stage 2. sticky tires Engine Management & Tuning 8 01-06-2005 03:35 PM
Question about Cobb AP & Utec Way2Slow Engine Management & Tuning 1 01-02-2005 10:15 PM
