Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 04-20-2005, 03:13 AM   #1
SR-71WRX
Member#: 31335
'09 WRX
SR-71
Default A tip for installing rear swaybar mounts:
This can be used for any rear swaybar mounts, but...
As many people know, the 04-05 rear swaybar mounts are much beefier than prior year wrx's and RS's. Therefore, all of us with the pre-2004 cars can go to the local subaru dealership and order these 2004-05 mounts for our cars as an upgrade to prevent breaking our wimpy mounts. They're also much cheaper than aftermarket heavy duty mounts.
The driver's side mount is a breeze (two 12mm bolts in plain view). The passenger side gives some people trouble because the rear bolt is behind the silver fuel filler tube.
It has been suggested that you use those ratcheting closed end wrenches to get into that tight space (which means you may have to go out and buy a set... not too bad, you might need em later but that's beside the point). This still makes the job much more difficult because you can really only turn the bolt a little bit at a time.
Solution:
1 - Remove your gas cap
2 - Remove the 3 gold colored screws that are surrounding the fuel filler tube.
3 - Go back underneath the car and now the silver fuel tube will move over just enough for you to use a conventional ratchet, extension, and 12mm socket.
4 - Once you remove the bolt and replace the old mount with the new one, remember to re-install those 3 screws... that should do it!
So this may be old news, however I did a search and thought that posting a thread might help someone else while searching the archives. I figured there have been a lot of people who have done this mod and there will be many more in the future wondering how to get to that bolt. This method worked flawlessly for me.
Cheers!
--Rob
sway bar swaybar mounts mount
SR-71WRX is offline   Reply With Quote
Old 04-20-2005, 05:54 AM   #2
kleinkid
Member#: 27091
2010 STi SE
Default smart for a young buck
I looked at your profile and it appears you are 14 years old. Is that correct? You were born in 1991? You are pretty sharp for your age, nice writeup, there is hope for our future yet!
kleinkid is offline   Reply With Quote
Old 04-20-2005, 11:29 AM   #3
SR-71WRX
Member#: 31335
'09 WRX
SR-71
Hahaha, I guess I should change that. It was an old SCIC joke from 2 years ago. I'm almost twice that age!
BTW... "klein" have to do with mtn. bikes?
Old 04-20-2005, 02:22 PM   #4
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Could just mean he is a little kid. klein= German for "small or little", resp. his whole screen name in German would be "kleinkind".
Arnie is offline   Reply With Quote
Old 04-20-2005, 02:47 PM   #5
HANZIE
Member#: 80319
04 WRX
lol...or maybe hes jewish.
klein is a jewish name
lets get the offical answer *waiting response*
HANZIE is offline   Reply With Quote
Old 04-21-2005, 12:23 AM   #6
kleinkid
Member#: 27091
2010 STi SE
Klein as in the manufacturer of of some very nice mtn. and road bicycles. Kid as in more fit than a lot of "kids". I am 52.
Old 04-21-2005, 12:54 PM   #7
coolcougar
Member#: 19674
2006 Baja Turbo 4EAT
Brilliant Silver Metallic
Thanks for the tip, Rob. Where were you a couple days ago...
I just installed my upgraded sway bar mounts Tuesday night after getting tired of looking at them sitting on my work bench for the last six months... I did have a set of those ratcheting closed end wrenches.. so it wasn't too bad... but trying to get that bolt started while installing the new mounts was a PITA... I wish I would have thought of this myself... it would have saved me about 20 mins, some skin off my knuckles, and some vulgarity.
coolcougar is offline   Reply With Quote
Old 04-21-2005, 06:36 PM   #8
SR-71WRX
Member#: 31335
'09 WRX
SR-71
Haha... sorry! Something else:
The mounts are two pieces... the big black bracket, and the goldish colored bracket that bolts to the black one. I found it kinda tough (on ONLY ONE of the gold brackets) to get the rear bolt in straight because it fit tight over the bushing which wouldn't let the holes line up. WHat I did was put the bracket on as best as I could with the front nut tightened halfway, then put the factory jack under the bracket and used that to push the gold bracket up against the car (don't crush the bracket). What this did was line up the two rear holes so I could get the bolt in. Hope that makes sense....
I should mention that it was probably a PITA because my Cusco rear bar is 22mm and I used the factory STI bushing which is meant for a 20mm bar. This made things a little bit tight but I didn't have to order any bushings off the internet... just went down to the local subaru dealer and got the bushings.
Old 04-21-2005, 08:06 PM   #9
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Don't the Cobb bars come with new bushings?
Old 04-21-2005, 08:13 PM   #10
Siper2
Member#: 1134
2010 Legacy GT Ltd.
Holy hell, someone WOULD post this up........ AFTER I installed mine.
Took me about 2 hours to get that sucker in there. Oh well.
=S2=
Siper2 is offline   Reply With Quote
Old 04-21-2005, 09:27 PM   #11
OneManArmy
Member#: 36154
2004 WRX Wagon
This post is awesome.
I wish I had read it before I did mine. That sucker is a PITA otherwise.
I put whitelines on my 04 wagon..didn't realize the 04's where better than the 03's until I took it off and went...woah...cool..these are way better than yours...to my buddy. So he put my 04's on his 02.
but yes..this is perfect advice and works wonders. Taking the tire off is a big help as well...obviously..haa.
OneManArmy is offline   Reply With Quote
Old 04-21-2005, 11:02 PM   #12
SR-71WRX
Member#: 31335
'09 WRX
SR-71
I'm sure they do, but I don't know of any aftermarket bars coming with the correct bushings for the stock 04 mounts. The stock bushings have the "ears" on either end that prevent the bushing from sliding out from the mount. My cusco bar came with bushings, but people have issues with these sliding out the side of the mount until your bar is rattling around in the mount. This is why you can go to the dealership and order the 05 sti bushings for a 20mm bar. They'll work perfectly even with a 22mm (like my cusco). I wouldn't try it with the huge 24mm whiteline bar though. For that bar you'll probably have to order one online somewhere.
OneManArmy - You don't need to remove your wheel. I have no clue how doing that would help
Old 04-21-2005, 11:31 PM   #13
Aerosim Research Ltd
Member#: 45648
GC8 CF 22B widebody
Lancia Stratos Replica
Default Cobb Bars
Aerosim Research Ltd is offline   Reply With Quote
Old 04-22-2005, 12:10 PM   #14
OneManArmy
Member#: 36154
2004 WRX Wagon
ummm...cause it takes all of a minute and you can see better and have better access to the bolt. It helped...a lot. Trust me.
Old 08-08-2007, 01:59 AM   #15
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 05 Saabaru
Well, this would have been useful 2 hrs ago.
Free bump...
Old 01-22-2008, 05:51 PM   #16
rubrduk
Member#: 126587
06 wagback...now
with more child seat!
bump for this being good stuff
rubrduk is offline   Reply With Quote
Old 01-22-2008, 07:14 PM   #17
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Yeah I discovered this technique when I installed a rear swaybar on my car that didn't come with one.
I have a set of the 04 mounts too but am waiting to buy a new bar before I put them on.
jamal is online now   Reply With Quote
Old 04-17-2008, 08:09 PM   #18
stewgod
Member#: 24412
2002 WRX - Wagun
OZs/DMS/PDE/Cusco/MRT
yeah - great post - just wish the shop that replaced mine had used an '04 one... now its gotta be done AGAIN.
THANKS A LOT
FYI: the 2004 replacements are only $12.00 each.... Whoo hoo a part that I can afford! (almost)
stewgod is offline   Reply With Quote
Old 04-18-2008, 04:17 PM   #19
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Awesome! I'm going to be changing up my rear mounts this weekend and I read this BEFORE I started the project!
bluescoobywagon is offline   Reply With Quote
Old 06-25-2008, 10:13 PM   #20
07wrxl
Member#: 173350
EVO 9
black
thanks for this it was so helpful!!
07wrxl is offline   Reply With Quote
Old 06-25-2008, 11:46 PM   #21
Butt Dyno
Member#: 17301
is the "dark side"
Glad people are finding it...
Old 08-14-2008, 03:33 PM   #22
bigstrusk
Member#: 118856
2000 GM6 STM
'07 S2K, '01 Ninja 250R
Could someone post up the part numbers of these mounts plzz?
bigstrusk is offline   Reply With Quote
Old 08-14-2008, 11:29 PM   #23
BIGSKYWRX
Member#: 7958
09 GH B+
Old 08-14-2008, 11:30 PM   #24
BIGSKYWRX
Member#: 7958
09 GH B+
Old 08-14-2008, 11:48 PM   #25
bigstrusk
Member#: 118856
2000 GM6 STM
Siiick, thanks BIGSKY. Now the real stumper, can I fit a 27mm Whiteline RSB in these? haha.
any tips for installing 2004 sti side skirts on a 2003 wrx? M32WRXin3seconds Interior & Exterior Modification 10 11-03-2003 03:32 PM
Tip for installing struts/springs eingram Brakes, Steering & Suspension 3 05-26-2003 11:03 PM
Tips for installing downpipe? Skippy5883 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-29-2003 03:50 PM
Tip for installing rear STB JulianH Brakes, Steering & Suspension 5 03-12-2001 11:03 PM
Tips For Installing STi 19mm RSB, Greg Links and STi Pedals SubePwr Technical Forum Archive 7 06-01-2000 08:38 PM
