04-20-2005, 11:31 AM | #1 |
Member#: 49297
NESIC
Vehicle:17 WRX Limited |
HID question: burn in time?
I read somewhere, something about burn in time for the HID bulbs. I just installed my 6K kit on monday, and have been driving with the headlights on since then, and not running the headlights with the car off. I did some research, and read the HID faq, but didn't see what i was looking for.
04-20-2005, 01:48 PM | #2 |
Member#: 57264
Vehicle:2004 18g Wagon - WRB PDX Tuned - 329whp/315wtq |
10 minutes after install, which is what McCulloch recommended
04-20-2005, 03:34 PM | #3 |
Member#: 67247
Vehicle:2003 2.5RS BRP SQC 189 |
10 minutes on the inital install/start and then you'll see full color after 50 hours of use.
04-20-2005, 04:13 PM | #4 |
Member#: 16157
South East
Vehicle:'03 Mazda P5 <>< '02 WRX & '08 MS3 SOLD!!! |
I'm assuming you're talking about color-shifting of the HID bulbs. They take anywhere from 50 - 100 hours of use for them to become more colorful
04-20-2005, 04:25 PM | #5 |
Member#: 49297
NESIC
OK, cause i ran the car for 15 minutes after install, but ive been driving with them on since. So i guess im ok
04-21-2005, 01:03 PM | #6 |
Member#: 36135
Vehicle:2005 WRX Aspen White |
That's Interesting. My passenger STI headlamp needed replacement and a new one is on order now. Will the color be significantly different than the driver's side? Should I order a new driver's side bulb so that both colors are even?
04-21-2005, 02:59 PM | #7 |
Member#: 67247
on OEM HIDs you will not see a big difference since they mass manufactured, you'll probably have to give it a day or 2 and it'll look just the drivers side. After market hid kit are manufactured in batchs which is why they recommend you to purchase a pair of bulbs even if 1 goes out.
04-21-2005, 03:29 PM | #8 |
Member#: 36135
thanks for the info!
HID Unit burned out. PISSED, HELP | BlackFighter | Electrical & Lighting | 10 | 11-16-2008 03:56 PM |
Spark Plugs (Split Electrode and Pressure Relief) - Burn Rate/Timing Effects? | Trunk_Monkey | Engine Management & Tuning | 3 | 02-24-2006 10:17 AM |
Burn in Period for HID | Blue_Diamond | Electrical & Lighting | 1 | 04-16-2004 09:42 AM |
HID question: Philips (Germany) or McCulloch? | gtguy | Interior & Exterior Modification | 22 | 10-29-2002 04:12 PM |
Burns in 5th currently in Corsica Rally! | Snoopy | General Forum Archive | 9 | 10-01-2000 12:46 AM |
