Old 04-20-2005, 11:54 AM   #1
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
Default Swaybar install- ramps or jack stands?
I have both and would rather use the ramps. The instructions wiht my Perrin endlinks says "Must Use Jackstands" but I was also under the impression that you should have the susspension loaded when installing them.
roybfr is offline   Reply With Quote
Old 04-20-2005, 12:08 PM   #2
symby
Member#: 7011
2002 Impreza WRX
I used jackstands to install both front and rear helix swaybars on mine. You might have some trouble hooking up the endlinks if the suspension isn't loaded. I've heard some have trouble putting the front subframe back on without the suspension under load as well. I had no problems and didn't use ramps at all.
symby is offline   Reply With Quote
Old 04-20-2005, 12:35 PM   #3
thesmokingman
Member#: 17751
2002 WRX Wagon
944 Turbo track
Ramps. That way you can tighten under load.
thesmokingman is offline   Reply With Quote
Old 04-20-2005, 12:37 PM   #4
HighSpeedRacerX
Member#: 36139
'06 LGT CDan - BSM
'85 Vette Beater w/NOS
Ramps for the rear to keep the suspension under load (easier to R&R the end links), stands for the fronts...you can use a jack to move the front suspension up and down to install the endlinks.
HighSpeedRacerX is offline   Reply With Quote
Old 04-20-2005, 12:40 PM   #5
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
^^what he said^^
Bishop is offline   Reply With Quote
Old 04-20-2005, 01:03 PM   #6
WWRRXX04
Member#: 61643
2004 WRX
World Rally Blue
I installed mine while on ramps. A set of rhinoramps gave me more than enough clearance and, as others pointed out, it keeps the suspension loaded which helps.
I'd also recommend wrapping a little teflon tape around the bar where the bushings contact it. My bars started squeeking a bit after a few months and the tape helped shut them up. It's a mod I read about in these forums... if you do a search you can find more info about it.
WWRRXX04 is offline   Reply With Quote
Old 04-20-2005, 01:17 PM   #7
ranger5oh
Member#: 77752
5Sti 2005 Sti
I used jackstands, then lowered it and finished tightening the bolts
ranger5oh is offline   Reply With Quote
Old 04-20-2005, 02:13 PM   #8
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
So what is the bennifit of using stands on the front? When you put it on stands do you just use the two points under the sides where you normally put the jack when changing the tire? That was my assumption. Also to jack up the front and rear do you use the reardiff and then for the front the jack plate (cross bar under motor).
I have been somewhat spoiled in the past, had access to a lift, then had a Quick Lift (sold as it took up to much room). No I have a set of Rhinos that are on a fest sets of 2x8 to give me about 10"+ of lift, or enough for me on the creeper to clear even with a bit of a belly.
Old 04-21-2005, 01:30 AM   #9
Impreza4ever
Member#: 62510
2005 Impreza Wrx Sti
WR BLUE PEARL
I did mines today, front and rear and i did both with the car on ramps. Pretty easy actually, took me 2 1/2 hours to do both, and im a first timer. Front was kinda easy taking into account that u have to drop the front member. The rear one was easy actually, the only thing that slowed me down a bit was changing the brackets, specially the one that is by the Carbon Canister, but getting the canister out of the way is pretty easy, 3 12mm bolts and thats it. Good luck
Impreza4ever is offline   Reply With Quote
Old 04-21-2005, 08:03 AM   #10
C Stoyer
Member#: 59394
2004 Impreza WRX
I did mine on ramps that lifted the car high enough to use a creeper. You find it will be so much nicer than crawling out from under the car to use a jack to push the wheel up to align the end link.
FWIW The instructions for my Hotchkis bars and end links said to torque the bars under load.
C Stoyer is offline   Reply With Quote
Old 04-21-2005, 08:45 AM   #11
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
Cool then ramps it is. Now I need to look for some steering bushing install instructions so I can do that while I am under there.
Old 04-21-2005, 09:10 AM   #12
PhilC
Member#: 35190
2003 WRX STX #77
www.soloracer.com
Ramps if you are just doing the swaybar, but that Perrin bar comes with new rear mounts and you're going to have to take off the passenger side rear wheel to get to the mount on that side. Un-hook and rehook the bar from the endlinks on the ramps (or on the ground) while it is un-loaded and then use jack stands in the rear and ramps in the front.
PhilC is offline   Reply With Quote
Old 04-21-2005, 09:15 AM   #13
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
Thanks. The bars are Cusco so I am not changing the mounts. Just have Perrin endlinks.
Old 04-21-2005, 09:57 AM   #14
PhilC
Member#: 35190
2003 WRX STX #77
www.soloracer.com
Reading comprehension p0wns me I guess. If not changing mounts use ramps.
Old 04-21-2005, 11:50 AM   #15
C Stoyer
Member#: 59394
2004 Impreza WRX
I did rear mounts with my install and there is no need to remove the rear wheel. You will nee the drop the charcoal canister down to change the mounts but thats it.
Old 04-21-2005, 12:24 PM   #16
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
Your ok I never said what bars I was using.
Ramps or Jack Stands subaru_steve General Community 64 09-21-2009 01:51 AM
What is safer? ramps or jack stands? mr2aniac Service & Maintenance 30 04-04-2008 10:53 PM
(VA) $20 for a Bunch of Stuff (Jack, Ramps, Jack Stands, etc) DriveFast MAIC Private Classifieds 6 02-26-2007 02:39 PM
Installing a catback Ö 2 or 4 jack stands? 04.SPT.WRX Service & Maintenance 17 09-26-2004 01:05 AM
TXS stage II install - lift or jacks? ezatnova Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-07-2002 02:52 PM
