#1 |
Member#: 16517
NESIC
Vehicle:09 WRX |
I am going to be putting on a used aftermarket lightened crank pulley and was curious if anyone knows what i should torque the bolt to? Is it the same as stock spec. or would it be less? Thanks
#2 |
Member#: 57264
Vehicle:2004 18g Wagon - WRB PDX Tuned - 329whp/315wtq |
stock (94ft/lbs), unless specified by the mfg
#3 |
Member#: 42992
South East
Vehicle:2002 WRX - Sold. 2005 Suzuki GSX-R 1000 |
just installed the Perrin Lightweight C.P. and their instructions said 90 ft/lbs but before torqued, you should apply a thin layer of engine oil on the crankshaft bolt threads and head base (the flat part which will contact the pulley).
Again, this is not my opinion but what the instructions read (I installed the pulley about 2 weeks ago) |
#4 | |
Member#: 59993
International
Vehicle:Ass, grass or cash no one rides for free!! |
#5 |
Member#: 42992
South East
no problem with the install. took me from 30-45 minutes. I don't see a year listed for your car but I think it should be the same as long as the miles are relatively low and mine are at about 34k for an '02.
the most difficult part was to remove the old pulley. pull on the top, then the bottom wiggling it as you go. eventually the pulley will come off. |
#6 |
Member#: 59993
International
thx for the info..... i've got an 04 w/about 27k on her.
#7 |
Member#: 51588
SCIC
Vehicle:2006 WRX TR 1997 Supra Turbo |
Hardest part is getting the stock pulley off. After you break loose the bolt, sliding it off of the peg it's on will be difficult. I used a giant pry bar and taught the thing a lesson.
Getting the belts back on afterwards was also a chore... but working it on with a BFScrewdriver did the job. |
| Thread Tools | |
| Display Modes | |
| SoCal: APS Cat, CAI, Greddy BOV, Crank Pulley, 12L Spec C | MINO | Engine/Power/Exhaust | 11 | 10-30-2008 12:11 PM |
| Crank pulley torque | XTTX | Newbies & FAQs | 12 | 06-21-2008 12:39 AM |
| pulley torque spec | gypsymoth | Service & Maintenance | 2 | 08-26-2002 01:10 PM |
| Pulley Torque Specs | DDMan | Normally Aspirated Powertrain | 5 | 06-09-2002 01:37 AM |
| Another pulley torque spec question. | Corn-Picker | Factory 2.0L Turbo Powertrain | 1 | 11-08-2001 09:08 PM |
