Old 04-20-2005, 03:06 PM   #1
wrex03
Member#: 29963
04 sti
Default tuna install ?
Do you have to tap the tuna into the ignition to run, or some other power source?
From reading the directioins, it seems that all you have to do (minus putting in the 02 sensor into the dp) is conect it to the utec via the serial cable and it will turn on with the utec, once the ignition is turned...
Did I miss something? It seems to easy!
Thanks,
Dave
wrex03 is offline   Reply With Quote
Old 04-20-2005, 03:34 PM   #2
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Thanks,
Dave
Heh, dunno... I just have a whole seperate distro block setup in my car that's all controlled via the ignition switch.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 04-20-2005, 03:50 PM   #3
Gethin
Member#: 2998
Gethin is offline   Reply With Quote
Old 04-20-2005, 03:54 PM   #4
wrex03
Member#: 29963
04 sti
^^ Missed seeing step 2 on that page.
Old 04-20-2005, 04:21 PM   #5
2phless
Member#: 69343
1998 TransAm cnvrtbl
The UTEC needs ignition of course, but I use the ACC switched power for the Tuner. If the tuner comes on before the UTEC, you can only log using the tuner. Hyperterminal won't "see through" to the UTEC. My UTEC takes a split second to warm up so it always seems to turn on slower than the Tuner.
By using the ACC, the tuner will lose power when the key is twisted into the start position, giving the UTEC the chance to power up before the Tuner, and then you can log and switch between UTEC and Tuner screens like normal. Even if I turn the key too quickly and the UTEC isn't fired up (car start kinda rough for a moment) I can gently twist the key towards start, but not all the way (the radio will cut off but the starter won't grind) and that resets the Tuner and I'm in buisness.
This may not be the case across the board. It's just what I've found.
2phless is offline   Reply With Quote
Old 04-20-2005, 05:14 PM   #6
happasaiyan
Member#: 37731
i think despite the precaution not to use the cigarette lighter power, i did...i think...
and i dont have problems with the utec/tuna initialization.
happasaiyan is offline   Reply With Quote
Old 04-20-2005, 08:30 PM   #7
wrex03
Member#: 29963
04 sti
Are you going to P&L on thursday? If so, I'd like to take a look at how you set yours up.
Old 04-20-2005, 09:09 PM   #8
happasaiyan
Member#: 37731
unfortunately, i cant make it. i really wanted to go to this one, but i have a previous engagement.
im too lazy to go take pics, so ill describe my install a bit.
i think i tapped the cigarette lighter power line. if its not that, then i tapped the radio 12v line. i havent had a problem with it like this.
the knock sensor and WBO2 sensor wires feed in through that black rubber piece behind the downpipe.
serial cable from UTEC, sensor wires, and power wires all feed up through the right side of the glovebox towards the bottom. you cant tell unless you stick your head by your knees. my tuna sits in the glovebox.
HTH.
turboxs tuna install problem cash1220 Engine Management & Tuning 0 02-14-2009 01:35 AM
My tuna install TheMadScientist Engine Management & Tuning 36 01-03-2005 09:28 AM
Tuna install with Forester DIN Pocket ScoreBo Engine Management & Tuning 6 01-01-2005 10:12 PM
TurboXS Tuner TUNA install help fatray Engine Management & Tuning 22 05-10-2004 10:14 AM
Tuna Installation pegdrgr Engine Management & Tuning 28 01-14-2004 08:35 PM
