Old 04-20-2005, 07:03 PM   #1
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Default Fuel Trims - What do you use to view them?
I was wondering what tools people are using to view long term and short term fuel trims. Hopefully at least one of them is inexpensive.
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 04-21-2005, 12:03 AM   #2
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
Any OBD scan tool will read the short and long term fuel trims. The SM3 or scanmaster 3 is a nice little tool for this and is subaru specific. The ultimate is Delta dash. It reads AFR corrections 1 and 2 and it reads the AFR learning. Plus it has lots of logging tools and a Road dyno feature among other things.
CLark
Kingpin is offline   Reply With Quote
Old 04-21-2005, 03:06 AM   #3
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
sm3 is cool.
santofontana is offline   Reply With Quote
Old 04-21-2005, 06:26 AM   #4
fmowry
Member#: 54604
2004 FXT
Cayenne Red (sold)
I'm cross posting this from the Fullthrottle forum (SM3s parent company). I'm beginning to wonder if the SM3 is a valid choice for logging. Is anyone using the SM3 to dispaly LM-1 A/Fs?
"I had the bad boost problem. Supposedly this was fixed. I've setup the SM3 to take the output of the LM-1 wideband. Changed OS to 1 to use analog 1 input. Setup Analog 1 input to 5 to read A/F.
One other note. The manual gives values of 1-5 for Analog inputs. The actual SM3 allows values from 0-5. So what is correct. None of them produced the same A/F as my LM-1 display though.
My A/F display on the LM-1 is .8 pts off. It never goes above 14.6 or so. I set up Analog 2 input to 5 also.
Is there some special way to set up the LM-1 to output what the SM3 expects? I thought it's default outputs of 0-5 v were what the SM3 is looking for.
I'm using a 3 ft stereo cable from Rat Shack to attach the LM-1 to SM3.
Are any of the other values valid? The voltage display seems low too but I haven't confirmed this with a voltmeter to the battery.
I was hoping to use this as my stealth boost gauge but looks like I'll have to install a boost gauge now too to check the values.
Could Fullthrottle developing the SM3 on a UTEC equipped Suby screw up more than just the boost values for other Subys?
My car is an 04 Forester XT with ECUtek reflash.
SM3, great tuning tool or $230 plastic box with flashing lights?"
Frank
fmowry is offline   Reply With Quote
Old 04-21-2005, 10:31 AM   #5
fmowry
Member#: 54604
2004 FXT
Cayenne Red (sold)
I'm going to ammend my comments regarding the A/F. Maybe I just need to know what the heck to program the LM-1 outputs to in order to have them display the same on the SM3 as on the LM-1 screen. Would be helpful if FullThrottle could have included this tidbit in their documentation since they do mention the LM-1 specifically.
Frank
What do you use to fit your fit, sills etc to the scoob.. Rice Devil Interior & Exterior Modification 0 07-12-2006 10:29 AM
What browser do you use to view the interweb? crowbar Off-Topic 16 07-15-2004 03:01 PM
What do you use to convert 128k mp3's to 44k? codemunky Off-Topic 3 05-25-2004 01:27 AM
What do you use to reattach rubber trim? Tomnel Interior & Exterior Modification 2 08-15-2002 10:03 PM
('93-'01) What do you use to wash your car? Mike Smith Impreza Forum 19 05-06-2001 08:33 PM
