Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 04-20-2005, 09:42 PM   #1
chrismindless
Member#: 73675
2004 WRX
WR Blue
Default 99RS 2.5L stock motor build up questions.
hi all,
currently its a 99 RS-T .. bought like that, and the engine is in bad shape.
In college so i dont have the time to do a swap, was thinking of using the stock ecu on the block BUT build the block to handle boost. Using an SafcII to handle the car now, runs great! BUT i have questions about where do i get the parts to lower the compression, and raise the revlimit ...
The time saved from not doing a ton of wiring, like in a swap, is money saved for internals.
any ideas or suggestions? any experiences?
chrismindless is offline   Reply With Quote
Old 04-21-2005, 11:27 AM   #2
Diz
Member#: 874
2015 WRX STI
2004 Mazdaspeed MX-5
Check out:
http://wac.addr.com/auto/obs/turbo/ejcalcs.html
See if you can source an EJ22t shortblock & re-use your heads. You may need to go aftermarket EM to raise the fun limiter.
Diz is offline   Reply With Quote
Old 04-21-2005, 12:48 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Any of the turbo short blocks would be a viable option. But it would be best to move this to the AFI forum for the best input. And before you do, get together exactly what the set up is, as in what turbo, intercooled, what EM, etc. etc. Then we can give you a ton of advice...
Old 04-21-2005, 04:27 PM   #4
chrismindless
Member#: 73675
2004 WRX
WR Blue
WOW! Thx guys!@ Thats exactly what i needed to know. Im moving this over to the AFI forum ... thx!
few questions about motor build up. thebasicnecessities Built Motor Discussion 2 04-25-2008 06:02 AM
my 2.5 motor build, and questions? spoolinred Built Motor Discussion 0 06-08-2006 01:35 AM
wrx motor build up questions azn2yunr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-04-2005 05:39 PM
slight build-up question (2.2+ 2.5 parts) Darby Normally Aspirated Powertrain 15 02-27-2003 12:26 PM
Questions on ej25 motor build up SCOOBYLOVER Normally Aspirated with bolt-on Forced Induction Powertrain 4 08-05-2002 02:37 PM
