Old 04-20-2005, 09:56 PM   #1
camshaftprelube
Member#: 54415
A strange
Tercel attraction
Default Short video of EJ22 powered Beetle
I was trying to do a stationary burnout, but it just pushes the locked front tires.
Please, right click, save as, borrowed bandwidth.
http://www.twistednipple.com/cars/P1010288.MOV
camshaftprelube is offline   Reply With Quote
Old 04-20-2005, 10:59 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
cool
dosn't really sound like a subaru :P
how about some details
are you using the stock ecu?
Old 04-20-2005, 11:36 PM   #3
camshaftprelube
Member#: 54415
A strange
Tercel attraction
What I was going for was an install that gave no external cues of anything funny going on. Keeping it looking gross is part of the charm.
'91 Ej22 with 150k miles. Harness and ecu were from a '90, a $50 eBay score. Engine adapter from www.kennedyeng.com. The vw starter could barely turn the engine over, so a gear reduction starter was bought from kennedy also.
Kennedy 1800lb pressure plate and Gene Berg spring hub dual-friction disc wrap up the clutch.
Modified Berg 'traction bar' loads the drivetrain against the body to reduce the tendency of destuctive wheel hop. I shattered a cv joint before I installed it.
The exhaust is a conglomeration of a few different parts. What's visible is what is commonly referred to as a 'dual quiet pack'. It's a sort of popular exhaust system for VW owners who have installed a header. Electrical conduit tubing was used as exhaust piping (it was on sale at home depot). The stock ej manifolds were chopped up and oxyactylene welded back together, then connected to a modified vw header. Works pretty good, but it's sort of ugly under there.
Nissan pulsar radiator is laid flat over the hole where the gas tank used to be, and the gas tank is turned 180 degrees and welded to an angle iron braket, putting it up near the firewall. More conduit tubing runs the length of the car for coolant to flow through. Now I have to open the hood to put gas in it.
Some cheap 17" dual-pattern wheels were gotten of of ebay for test fitting. That's what's on the back. To get them to fit up front requires narrowing the front beam and then running wheel spacers. A lot of work. I have the front beam narrowed already. Need to get my front rotors redrilled. Was originally going for modern porsche wheels, but I couldn't afford them.
I took it to Virginia Motorsports Park for test n tune day sometime during the summer last year. It literally had been running for a week. A lot of bugs, noticeably I was only getting about 3/4 throttle, and I couldn't launch it because of no drivetrain bracing (massive wheel hop). Also, a crappy homemade shifter made shifting quickly with accuracy impossible. I basically had to roll it slowly off of the line. It did a 15.1 at 88. Sucky, but I plan to do some more runs this summer. I think it will do low 14's easily. I was being paced by a friend in a del sol late one night, top speed seems to be 130ish (gear limited). Bugs shouldn't be driven that fast. It's effin' scary.
Old 04-20-2005, 11:43 PM   #4
camshaftprelube
Member#: 54415
A strange
Tercel attraction
A couple more notes:
The oil pan is about 1/2 an inch thick. I armored it after putting a hole in the pan in the first half mile of the first drive. 14 inch wheels suck.
The transmission is stock, from a superbeetle. Mobil1 synthetic gear oil inside. One cv shaft doesn't have any boots on it.
This was my very first car. I've had it for 11 years now.
Old 04-21-2005, 12:04 AM   #5
fasterthanrayswrx
Member#: 48672
2005 Subaru
WRX
thats funny. any pics of the car? engine shots?
fasterthanrayswrx is offline   Reply With Quote
Old 04-21-2005, 12:51 AM   #6
camshaftprelube
Member#: 54415
A strange
Tercel attraction
Yeah, but they look really, REALLY bad. The car has some rust issues. And I was going for function over form.
Screw it, here you go.
Old 04-21-2005, 01:21 AM   #7
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
thats a cool car
jared nelson is offline   Reply With Quote
Old 04-21-2005, 01:30 AM   #8
camshaftprelube
Member#: 54415
A strange
Tercel attraction
Anyone in Richmond, or in VA that wanna check it out PM me.
Old 04-21-2005, 02:10 AM   #9
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
Sweet. I cant believe you welded on that gas tank . Did you cut out the trunk pan under the rad? Fans blow down or suck up? either way you should have a hood scoop of some kind. No trouble with air pockets..over heating?? How much hacking did you have to do to fit the engine?
Scoobie Steve is offline   Reply With Quote
Old 04-21-2005, 03:29 AM   #10
fasterthanrayswrx
Member#: 48672
2005 Subaru
WRX
Thanks for the pics
Very nice...still can't get over the idea of a Subaru powered Bug
Old 04-21-2005, 05:22 AM   #11
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
Where is the turbo? Screw burnouts I want to see some wheelie's Pretty sweet though. I've had an idea of trying to make one awd so that I could have a sweet drag car but money's always a factor.
speed_freak27 is offline   Reply With Quote
Old 04-21-2005, 08:59 AM   #12
camshaftprelube
Member#: 54415
A strange
Tercel attraction
The gas tank had been dry fr about 6 months. Still scary though. The spare tire well is cut out for air. The fans blow down. It's a pain in the ass to get all the air out of the cooling system, but I haven't had any problems since then.
Part of the rear apron had to be cut to fit the engine in there. The throttle body is really close to the firewall, and instead of flipping the intake around, I cut a hole in it with a sawzall.
Old 04-21-2005, 09:02 AM   #13
camshaftprelube
Member#: 54415
A strange
Tercel attraction
I think if it ever hooked up, it might pick a tire off of the ground. Don't know. I decided that keeping a stock Ej22 was the best idea, the stock VW transmission can handle maybe 150 hp, I didn't want to have one custom built.
Custom built VW transmissions are cheap as hell though. Maybe I'll put a 50 shot on it.
Old 04-21-2005, 10:03 AM   #14
steve_d
Member#: 315
that's pretty cool...
I've got an EJ 18 in my porsche... search on porscharu.
not sure how many pics will still show up...
sjd
steve_d is offline   Reply With Quote
Old 04-25-2005, 02:48 PM   #15
Will98RS
Member#: 15816
1998 Impreza RS
i want to put an ej22t in a karmann ghia but i want to try to do it as a mid engine
Will98RS is offline   Reply With Quote
Old 02-01-2008, 12:46 AM   #16
1974SubaruVW
Member#: 170612
1974 VW Subaru EJ22
Green
Default New Owner of Subaru EJ22 in VW
Greetings all. The 1974 VW with Ej22 Subaru engine has just changed hands. I am now the proud owner. If anyonw needs pointers or update on the car just send a post here. I am stripping it down as we speake to repaint it and upgrade the engine components. This should be a 5 month project but it will be well worth it.
74SVW
1974SubaruVW is offline   Reply With Quote
Old 02-01-2008, 01:47 PM   #17
steve_d
Member#: 315
where in teh sE are ye?
sjd
Old 02-01-2008, 11:02 PM   #18
Scoobie Steve
Member#: 2289
1998 11.87@112mph
74SVW
So you are the one that clicked "buy it now" I was watching this car. Glad it found a good home that will provide some finishing touches.
Old 02-05-2008, 12:54 AM   #19
bagelicious
Member#: 141030
98 Legacy GT
Spruce Pearl
Video link doesn't work!
Anyone got a mirror?
bagelicious is offline   Reply With Quote
Old 10-28-2008, 11:43 PM   #20
camshaftprelube
Member#: 54415
A strange
Tercel attraction
I just saw this. Any updates?
short video of the broken Power steering pulley reddevil Normally Aspirated with bolt-on Forced Induction Powertrain 7 01-04-2005 02:50 AM
Short video of Russell's new sub Verdugo North West Impreza Club Forum -- NWIC 0 04-20-2003 03:41 AM
Short Video of me in the snow. 2.5RSMatt Member's Car Gallery 9 04-18-2003 09:32 PM
can someone host a few short videos of my car? juztin180 Member's Car Gallery 0 01-01-2003 11:44 PM
Short video of the outback seeing snow for the first time. remarcable Legacy Forum 0 01-03-2002 10:26 PM
