Old 04-21-2005, 10:25 AM   #1
chrisfranklin
Member#: 59737
2004 sti
crappy subaru white
Default unmarrying AP... w/special circumstances
well, i'm not the brightest bulb in the batch...
removed tmic, manifold, uppipe, turbo, injectors, downpipe...blah blah
forgot to unmarry my ap prior to this.
need to send off my ecu for an ecutek reflash.
do not want to reassemble car for simple unmarrying process.
Q: is it possible to plug my ecu into another 04 sti and unmarry my ap?
thanks for looking,
chris
chrisfranklin is offline   Reply With Quote
Old 04-21-2005, 12:03 PM   #2
MeetMrGlock
Member#: 50885
04 CUTN EDG STi
neanderthal blackout
no, but you don't have to.
you can remove any part EXCEPT for the battery and the ecu to unmarry your ap. just plug it in and get busy.
MeetMrGlock is offline   Reply With Quote
Old 04-21-2005, 12:07 PM   #3
chrisfranklin
Member#: 59737
2004 sti
crappy subaru white
for some reason, when i connected the green connectors and turned the key to the on position the car started acting funny.
gauge sweep kept repeating, fans turning on/off, etc
and when i tried to unmarry the ap, it kept reading error.
:dunno:
Old 04-21-2005, 12:22 PM   #4
MeetMrGlock
Member#: 50885
04 CUTN EDG STi
i don't have my manual in front of me but i believe youre supposed to have all accessories, fans, etc., turned off.
i see youre in ky. cobb should be open right now. i'd call and have them walk you through it.
Old 04-21-2005, 12:29 PM   #5
ranger5oh
Member#: 77752
5Sti 2005 Sti
The fans and stuff come on in diagnostic mode.. you will hear all sorts of stuff... that means its working.
You should be able to unmarry your AP as long as the battery is hooked up.
ranger5oh is offline   Reply With Quote
Old 04-21-2005, 07:05 PM   #6
Kantalias
Member#: 50800
2004 Impreza WRX
Platinum Silver
Maybe try the alternate method:
If it is a MY04+ WRX model, attempt an alternate method of programming which involves connecting the AP only after the car has been placed into Test Mode and key is in the ON position and never turned off even when prompted by the AP.
This is from the COBB KB. I'm not allowed to post URL's yet, but it's the issue titled "ERROR, please try operation again message?"
Kantalias is offline   Reply With Quote
Old 04-21-2005, 10:03 PM   #7
chrisfranklin
Member#: 59737
2004 sti
crappy subaru white
just swapped my ecu into a friend's 04 sti, unmarried and done.
thanks for the replies though
Unmarried AP and Keeping Old Maps Gordata Engine Management & Tuning 3 10-29-2005 02:00 PM
married/unmarried ap Spooln4 Engine Management & Tuning 6 07-20-2005 02:57 AM
Unmarried AP? brex16 Engine Management & Tuning 13 06-25-2005 01:37 PM
unmarrying AP from 05 sti? z_wrecker Engine Management & Tuning 3 03-28-2005 09:02 AM
Help! Unmarrying AP now car won't start! ScoobyNubieToo! Engine Management & Tuning 7 03-09-2005 10:38 PM
Message Board Statistics All times are GMT -4. The time now is 07:11 AM.
