Old 04-21-2005, 11:41 AM   #1
keyser_soze
Member#: 57445
Default StreetTUNER 1 - 2 - 3
OK read the manual and did some research on the forums but summerize it for someone that never has had an AccessPort nor any other Cobb parts (ME):
1. Hook up the Accessport to your PC with the ST software installed
2. Updated the AP
3. Connect the AP alone directly to the ODB-II port (while having the green connector on)
4. Flash the Ecu using either StreetTUNER update or Stage 1 or Stage 2 maps
^^^^ These are Base maps ~ I flashed the StreetTUNER update map which I assumed is a stock 05 STi map
5. I am building a ST map...as I am editing and making my map I am saving it as a ST base map on my laptop
6. So my question....when I'm done building my map what do I do? I save it as a real time map and load it or flash it into the ECU using the ST software or put it in my accessport and flash it?
Thanks
keyser_soze is offline   Reply With Quote
Old 04-21-2005, 12:19 PM   #2
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
If you build a realtime map while connected to the car, your changes are already in place as a realtime map on the ECU. If you're desk tuning, you'll need to load it into the car. You can do that by loading the map into ST while connected, or load it onto your AP and then connect the AP to the car and upload it.
If you do a basemap, you'll have to load it into the AP and then flash the car with the AP.
mrbell is offline   Reply With Quote
Old 04-21-2005, 12:35 PM   #3
ranger5oh
Member#: 77752
5Sti 2005 Sti
Yep... thats the beauty of our ST software. I would reccommend keeping it as a realtime map until you are sure it is perfected. You can make realtime changes to the realtime map while the car is running. Its pretty sweet.
Anyway, if you are making a stage 2 map, Id like to see it when you are done....please.
Good luck!
andy.
ranger5oh is offline   Reply With Quote
Old 04-21-2005, 12:46 PM   #4
keyser_soze
Member#: 57445
OK, so in summary can I use my base map without flashing it? or i have to save it as real time map?
Thanks
Old 04-21-2005, 02:26 PM   #5
HonduHunter
Member#: 28408
2002 vf48ed WRX
no a base map is used for a reflash. real maps are used without flashing. you will need to save it as a realtime map.
MZM doesnt tune cobb do they?
HonduHunter is offline   Reply With Quote
Old 04-21-2005, 03:44 PM   #6
keyser_soze
Member#: 57445
Thanks for the replies.
MZM does tune Cobb ST.
Old 04-21-2005, 04:00 PM   #7
clamdip
Member#: 18709
how are you guys tuning your street tuners? i don't have much of a stretch of road to work with where i live, nor a AWD dyno. any suggestions? i'm guessing i could use deltadash and datalog, then use the street tuner to adjust the numbers and generate a map. sound possible?
clamdip is offline   Reply With Quote
Old 04-22-2005, 02:49 AM   #8
HonduHunter
Member#: 28408
2002 vf48ed WRX
you can log with the street tuner.and go to a race track.
Old 04-22-2005, 12:31 PM   #9
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Whats a good starting point to begin tuning?
Big-Sexy907 is offline   Reply With Quote
Old 04-22-2005, 04:06 PM   #10
R4ND0M_AX3
Member#: 67483
2005 WRX STi
Logs, logs, and more logs. Then study those logs.
R4ND0M_AX3 is offline   Reply With Quote
Old 04-22-2005, 04:25 PM   #11
HonduHunter
Member#: 28408
2002 vf48ed WRX
then make more logs
Old 04-23-2005, 02:08 AM   #12
buzz313th
Member#: 37008
2005 WRX Sedan (STX)
Crystal Grey -TeamBrew-
With ST you can just save any changes as a base map... no need to save as a realtime map, because you can just load the base map when live tuning is active and all the realtime calibrations will be loaded into the ecu. In my opinion, the only reason to save a realtime map is if you are gonna use it as a realtime map on the AP.
Basically what I am saying is..... The realtime calibrations from a basemap will load into ecu just like realtime calibrations from a realtime map, you just not loading the base changes till you flash the ecu...
buzz313th is offline   Reply With Quote
Rosetta stone 1/2/3 Latin America Version 2 0260B4U Non-Subaru Stuff 2 07-31-2009 06:48 PM
Vivid Racing Stage 1/2/3 bobafett Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-21-2002 10:45 PM
Subaru 1,2,3, at the CRAB Rally TOMMY B Motorsports 0 07-08-2001 10:24 AM
Automatic transmission: is using 1-2-3 gear in town hard on transmission? subymamma Normally Aspirated Powertrain 28 04-30-2001 05:30 PM
Testing, 1, 2, 3 wolve80 Mid West Subaru Owners Club Forum -- MWSOC 9 05-28-2000 04:09 PM
