Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-21-2005, 11:46 AM   #1
drfrink24
Member#: 36369
2004 WRX STi
Java Black
Default Base map vs. real time stage 2
I have the AP for my 04 STI. As many of you may know, you have base maps and realtime maps. The supposed advantage of RT maps is that you don't have to reflash the ECU, which has a limited lifespan in its reflash count.
But, what really is annoying me, is that most threads and cobb tuning themselves recommend running the base map as your primary map, because it has more control over ECU parameters.
If you're reflashing the ECU on the base map everytime, then, it kinda defeats the whole purpose of limiting re-flashes, doesn't it?
The reason I bring this up, I'm going to stage 2 this weekend, and I'm pretty sure I'll reflash to 93 stage 2. Is this what others would recommend?
drfrink24 is offline   Reply With Quote
Old 04-21-2005, 11:56 AM   #2
Drayton
Member#: 44055
2003 WRX
Click here
That thread may be helpful.
Drayton is offline   Reply With Quote
Old 04-21-2005, 12:16 PM   #3
drfrink24
Member#: 36369
2004 WRX STi
Java Black
Yes, that helps. Confirms my other findings.
Still seems though, running stage 2 93 base and HWG or LWG RT would yield different results than HWG/LWG basemap and stage 2 93 as RT.
Would be nice to know what all these mysterious "parameters" are better controlled as base than RT.
Old 04-21-2005, 02:02 PM   #4
Drayton
Member#: 44055
2003 WRX
Straight from trey. Hope it helps
click me
XTM map upgrade from cobb stage 2 base map?? hella_sti AccessPort 0 03-26-2008 10:36 AM
Dyno Flash Pro Tune vs Cobb Base Map on 04 WRX Stage 1 93 octane Dyno Flash Proven Power Bragging 13 10-26-2006 02:09 PM
Base Vs Real Time Hypnotk AccessPort 8 03-27-2006 09:53 AM
Base Map and Real-time? NWWagon Newbies & FAQs 12 04-17-2005 09:05 PM
utec stage 2 base map vs tune LatentWagen Engine Management & Tuning 21 06-20-2004 09:32 PM
