Old 04-21-2005, 02:25 PM   #1
billy boi
Member#: 19714
.... front cover of
MODIFIED MAG Sept. 2006
Default what radiator overflow tank to use with Hyperflow FMIC ?
mines didnt come with one and right now im using a powerade bottle . though its original and ghetto , im entering a show and judges might-might not like it . anywhere i could get one at ? if not , i was thinking about walking around home depot for like 2 hours looking for something to make one . any ideas ? thanks
billy boi is offline   Reply With Quote
Old 04-21-2005, 02:51 PM   #2
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
I used Aquafina for awhile (seriously) until the guy I bought the ic from sent the hyperflow one. I believe you can get a billet one for $$$ if you are showing the car. Do a search. Aquafina is 2 more hp than Gatorade imo
rjrutzky is offline   Reply With Quote
Old 04-21-2005, 03:41 PM   #3
billy boi
Member#: 19714
.... front cover of
speedmonkee sells like a polished one . but its the same size as the stocks .
Old 04-21-2005, 04:33 PM   #4
BoostedAWD
Member#: 19519
2002 Subaru WRX
World Rally Blue
use ur stock one and just reroute the lines.
its only an overflow tank...and as long as it isn't higher than the resivior...you're good.
BoostedAWD is offline   Reply With Quote
Old 04-21-2005, 04:45 PM   #5
billy boi
Member#: 19714
.... front cover of
theres no space under my hood . its too big
Old 04-21-2005, 05:42 PM   #6
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
billi boi a long silicon coupler would make a good one... the perrin came with one of those.
LatentWagen is offline   Reply With Quote
Old 04-21-2005, 05:46 PM   #7
SooobieSnack
Member#: 44380
Try Canton. They'll fabricate anything you need.
SooobieSnack is offline   Reply With Quote
Old 04-21-2005, 07:08 PM   #8
speedblind
Member#: 42202
Any hot rod/speed shop will have what you need - polished canister with fittings. Or you can order one here.
http://www.jegs.com/cgi-bin/ncommerc...35&prmenbr=361
Good luck.
speedblind is offline   Reply With Quote
WTB (NY): Radiator overflow tank for FMIC Gabriel~ Private 'Wanted' Classifieds 1 03-25-2009 04:00 PM
What Rails and Brackets to use with Recaro Side Mounts? xmystikx Interior & Exterior Modification 3 09-28-2006 08:09 AM
What splitter to use with TXS / Hyperflow TMIC? ronaldwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 03-24-2004 03:54 PM
Small radiator overflow tank american GC8 ? bigbird Normally Aspirated with bolt-on Forced Induction Powertrain 8 05-02-2003 01:58 PM
What minor lowering springs to use with SPT kit? Frederf Brakes, Steering & Suspension 4 01-10-2003 01:16 PM
