Old 04-21-2005, 07:49 PM   #1
dlewis
Member#: 76948
2002 Impreza Wrx
Default Smoke After New turbo Install
Hey guys, I just installed a SBR gtr-12 turbo on my Wrx along with rc engineering 650cc injectors and heat range 7 plugs. Im getting a lot of smoke it appears to be coolant smoke when I get on my car. Its untuned as of now but that will change shortly. When it smokes its a huge cloud of smoke like its just pouring out. What could be the problem? I smelt it it smells like coolant. When I just drive easy it doesnt smoke at all but as soon as I begin to boost it will smoke. I replaced this from my stocker because the stock turbo had its oil seals going and it also would smoke when i got on it. What do you gurus think could possibly be wrong with this?
dlewis is offline   Reply With Quote
Old 04-21-2005, 08:07 PM   #2
Starkiller
Member#: 82741
2007 350Z Silver
Is your new turbo water cooled? If it isn't, hopefully you closed up the old coolant line that went into the stock turbo.
Starkiller is offline   Reply With Quote
Old 04-21-2005, 08:12 PM   #3
dlewis
Member#: 76948
2002 Impreza Wrx
the slowboy racing turbo is oil and water cooled.It beats me on what it could be.
Old 04-21-2005, 08:48 PM   #4
dlewis
Member#: 76948
2002 Impreza Wrx
bump..
Old 04-21-2005, 09:14 PM   #5
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
Check the IACV gasket, pressurize the charge pipe and see what leaks, check the compression with all the plugs out yadda yadda
overdose is offline   Reply With Quote
? about after my new turbo install mucky Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-22-2008 10:55 AM
After new turbo install, feels like fuel cut-off at 7psi.... WRXfoME Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-19-2007 03:43 PM
new turbo installed. smoke screen, low o2 voltage, no boost chris124816 Normally Aspirated with bolt-on Forced Induction Powertrain 24 01-20-2006 07:44 AM
how much est. horses...after new turbo and IC install SWEETWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-29-2002 04:45 PM
Is it normal for a car to smoke after an uppie installation? Corn-Picker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-11-2002 04:58 AM
