Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-21-2005, 08:03 PM   #1
cliffhanger
Member#: 80446
2005 5spd Baja-T
370+405=new clutch
Default mbc install
ive got a perrin mbc and want to install it at about 13 psi... problem is im not to smart about all these f* *ng little vacuum hoses and what all they go to... can anyone help out with pics or a good explanation as to which hoses to cut into and which way to install the mbc? thx
cliffhanger is offline   Reply With Quote
Old 04-21-2005, 08:22 PM   #2
Hawk296
Member#: 14555
1995 L (Apex Tiger)
Battle Ready Baja
Hmm... first off I have NOT done this, so take it for what is worth... I am kinda worried that youre installing a MBC yet really dont know where it goes. I hope you have an accurate boost guage and are really careful, these things can be dangerous.
I know for sure there are several writeups un this install on the internet for WRXs and FXTs, yours should be pretty much the same. The only vacuum lines you need to mess with are the ones for the wasegate actuator. If I recall, a line comes out of the compressor side of the turbo, T's off, one side going to the factory boost solinoid and the other going to the wastegate actuator (little tin can diaphram thingy with a rod coming out). You should be able to disconnect the line to the factory boost solinoid, then insert the MBC in the line between the nipple on the compressor side of the turbo and the wastegate actuator.
THis should help you at least locate the lines in your car. Try searching the web for installs on SUbies and also follow the instructions for the Perrin (pretty basic, yet pretty good). Hope this helps you in some way. Good luck, be careful.
You can also install it in place of the factory boost controller, I am not really sure what you had in mind.
Hawk296 is offline   Reply With Quote
Old 04-22-2005, 08:21 AM   #3
mjalex007
Member#: 66022
2005 Baja Turbo
There are instucts on Scooby Mods: MBC instructions
I would re-emphasize: You must have a boost gauge or you will not be able to set it correctly.
mjalex007 is offline   Reply With Quote
Old 04-22-2005, 07:07 PM   #4
cliffhanger
Member#: 80446
2005 5spd Baja-T
370+405=new clutch
alright, sweet, thanks guys, this is what i thought, but i really like pics... the instructs are just words, and me being a guy, i really wanted to see it before i took it all apart. this will def go in when i get my baja back!
MBC install...?????'s Scooby South Factory 2.0L Turbo Powertrain 7 07-10-2001 11:01 PM
Hallman MBC, installed please help en3d Factory 2.0L Turbo Powertrain 4 06-13-2001 12:45 AM
MBC install (WRX)...? jdgti Factory 2.0L Turbo Powertrain 18 06-10-2001 01:13 AM
MBC installed...observations... jdgti Factory 2.0L Turbo Powertrain 19 05-16-2001 05:24 PM
dawes devices mbc installed RidinLow Factory 2.0L Turbo Powertrain 27 04-21-2001 01:48 PM
Message Board Statistics All times are GMT -4. The time now is 11:07 AM.
