Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-22-2005, 08:20 AM   #1
SpyderBaja
Member#: 85028
2005 Baja Turbo
BLACK!
Cool How to Remove the Door Panels
I just purchased 4 Polk DB650's to put into my brand new (YEAH!) 2005 Baja Turbo. I took a quick look at the door panels this morning and couldnt see how i would get them off. If someone could help out a Baja Noob i would really appreciate it.
PS: I LOVE THIS CAR!!!!!!!!!
SpyderBaja is offline   Reply With Quote
Old 04-22-2005, 09:13 AM   #2
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
You could do a search since this is a common question. That would point you to this web site.
braveit1 is offline   Reply With Quote
Old 04-22-2005, 09:20 AM   #3
Dan C
Member#: 85601
2004 Baja Turbo
First, remove the ovaloid plastic trim piece around the door handle/opener. Then, on the armrest that is integrated into the door, there is a small, square plastic cover that conceals a screw. With a screwdriver, pry out the plastic piece, and then remove the screw. Then, use a prying tool to pry out the plastic button cluster-windows, locks-and undue the wiring harnesses. Beneath the where the button cluster used to be is another screw. Undo that one, and your pretty much done. There are pop on-pop off clips that go around the sides and bottoms of the door. You just use, for example, a paint scraper to pry these off. the door will then be hanging from the top of the door, still set in place by the top of the door which fits into a crevice right next to the window. Lift this up and away from the car, and its off. Pictures would be nice, and my language is somewhat fuzzy, but i hope this is helpful. PS, there is a little light on the corner of the door which also has a wiring harness. Remember to release thsi
Dan C is offline   Reply With Quote
Old 04-22-2005, 09:26 AM   #4
SpyderBaja
Member#: 85028
2005 Baja Turbo
BLACK!
Thanks for all the help, i cant wait to try this as soon as i get out of work, assuming my tint job is done!!
Old 04-22-2005, 09:48 AM   #5
mjalex007
Member#: 66022
2005 Baja Turbo
You're probably going to need adapters for the speakers... I don't think the mounting holes on those speakers and on the door line up.
mjalex007 is offline   Reply With Quote
Old 04-22-2005, 09:51 AM   #6
SpyderBaja
Member#: 85028
2005 Baja Turbo
BLACK!
What sort of adapters am i going to need? can i get them a Circuit City; Best Buy or someplace local?
Old 04-22-2005, 12:25 PM   #7
mjalex007
Member#: 66022
2005 Baja Turbo
You can buy them on line. Company called Scosche makes them. I don't know if Best Buy etc. sells them. What most people seem to do is make them out of thin plywood.
Here is an example of what the adapter looks like: ones...Scosche
Old 05-02-2005, 04:44 PM   #8
2003Baja
Member#: 52985
did you pop em in yet? Door panels are EASY to remove. used a flat head screwdriver to "pop out" the window switch/door lock controls and the rest was cake. 2 screws and the rest is clips.
2003Baja is offline   Reply With Quote
Old 05-04-2005, 10:34 AM   #9
SpyderBaja
Member#: 85028
2005 Baja Turbo
BLACK!
I did get them in, it was very simple! Though i am not impressed with the way they sound with the stock headunit, i am going to be replacing it with a Clarion DXZ955MC with a 4 channel amp comming in the future then the Mac Mini and subs and the list keeps going....it will never be done!
Old 05-04-2005, 03:27 PM   #10
2003Baja
Member#: 52985
One thing always leads to another
I need to find a place that sells an aftermarket altenator. 1600 watts puts a strain on the stock one
Old 05-04-2005, 04:29 PM   #11
cliffhanger
Member#: 80446
2005 5spd Baja-T
>300WHP White/Silv Cruck
if you find an aftermarket alternator, let me know!
cliffhanger is offline   Reply With Quote
Old 05-04-2005, 04:33 PM   #12
Hawk296
Member#: 14555
1995 Impreza L
Baja
At least the Bajas get the 90A alt vs the standard 75A.
Hawk296 is offline   Reply With Quote
Old 05-05-2005, 08:00 AM   #13
SpyderBaja
Member#: 85028
2005 Baja Turbo
BLACK!
I have also been looking into a new alternator, but not sure what will fit, if anyone finds one that does, i am very intrested!
Old 05-05-2005, 09:23 PM   #14
2003Baja
Member#: 52985
I second that
Show me how to remove the side panel of the Roof spoiler!!!! jumbosushi Interior & Exterior Modification 2 07-23-2007 11:28 PM
I need to know how to remove the door panels of a 04 R.S sergio78 Interior & Exterior Modification 1 04-04-2006 12:10 AM
How to remove 2005 door panels brad_in_denver Interior & Exterior Modification 5 01-29-2005 11:30 PM
How do I remove the door panels on an L (manual windows)? ilmaestro Service & Maintenance 2 04-13-2004 10:52 PM
how to get the door panels off? blueimpreza25rs Newbies & FAQs 4 09-26-2003 01:58 AM
